Switched to 3.73 gears and not loving it
Discussion in 'High Performance Modifications' started by sinnyz_me, Jul 7, 2018.
  1. Zspoiler
    Zspoiler Veteran Member
    3,371
    276
    May 6, 2012
    Federal Way, Washington
    I have driven Camaros with 3:73 and 3:42 `. And I prefer the 3:42`s because its a good compromise gear.Its gives you decent gas mileage with good performance, I have 377 cubic inch supercharged small block.Super T-10 trans,
    sinnyz_me likes this.
  2. sinnyz_me
    sinnyz_me Veteran Member
    104
    Jul 23, 2006
    Des Moines, IA
    ok gotcha, what do you run in your car or what do you recommend?
  3. sinnyz_me
    104
    Jul 23, 2006
    Des Moines, IA
    Yes, I think it would worth it for sure.
  4. sinnyz_me
    104
    Jul 23, 2006
    Des Moines, IA
    What are your rpms at highway speed?
  5. Zspoiler
    3,371
    276
    May 6, 2012
    Around 2500 at 60 MPH with a 26 inch tall tire .right in its sweet spot, Got around 24 MPG.
  6. Twisted_Metal
    27,312
    1,123
    I have a 200-4R with 3.42 gears. (255/60-15 tires on the rear.)
    It turns 2000 RPM @ 70 MPH.
    Your 3.73 gears would put it around 2250 RPM @ 70 with the same tires.
    A 700-R4 would be slightly higher RPM. (0.66 in the 200-4r Vs .7 OD in the 700R4 )
    It's getting hard to find a good 200-4R.
    700-R4 are still pretty common much if you have the means to do it once and right.... the 4L80E would be what I would look at first.
    I swapped mine to the 200-4R over a decade ago but you have more options available to you today.
    My son has 4.10 gears on his Camaro and he went with a 200-4R.
    He can actually comfortably run his at freeway speeds now.
  7. NYH1
    NYH1 Veteran Member
    1,601
    12
    Feb 27, 2010
    Central New Yorkistan
    Ever think of going with a Tremec TKO 5 speed? Depending on the trans. you choose, you can get a .64, .68 or .82 overdrive gear.
    Just a thought, NYH1.
  8. Bandit723
    Bandit723 Veteran Member
    3,150
    464
    Oct 1, 2016
    Waupaca WI
    700-R4's are good for cruising and do hold up if done right. For performance folks the 4L80E is attractive give a first 3 gear ratio as a TH400 and are beefy. Down side they are a bit heavy and are more costly to build.
  9. ssupercoolss
    ssupercoolss Veteran Member
    806
    228
    Nov 3, 2015
    PA
    Overdrive trans are awesome.
  10. larrylarry
    larrylarry Veteran Member
    1,553
    72
    Dec 22, 2011
    San Antonio Tx
    I have a 700r4 in my 78 with 3.42’s. At 70 mph the rpm’s are 2200. I could easily switch to 410’s an still be lower than your rpm’s. 200r4 or 700r4 is the way to go but like said if you’re running a high HP/torque engine then a 4l80e would be the choice.
