T/A Hoods
Discussion in 'Body Restoration' started by NeoNeuro, Nov 11, 2016.
  1. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    Does anyone know if a Firebird hood will fit a Camaro? I saw a really sweet setup on a 73 T/A that I would like to replicate if I can, but I'd have to use a Firebird hood with the scoop hole to do it. Thanks.
  2. NOT A TA
    NOT A TA Veteran Member
    237
    82
    Feb 12, 2009
    Delray Beach Florida
    Could you cut a shaker opening in a Camaro hood to do the modification you want? The body lines are different even if the hood would physically fit.
  3. 351maverick
    351maverick Veteran Member
    3,614
    390
    Aug 11, 2010
    erie, PA
    the hoods are different
    and a Pontiac shaker scoop on a Camaro would look pretty stupid
    sorry
  4. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,376
    83
    Feb 2, 2008
    SF
    I have a hood opening I might sell
  5. hoppin5478
    581
    98
    Jul 20, 2015
    Tucson, AZ
    I have a 77 TA hood and shaker set up in storage if you need some measurements, if that year helps at all.
  6. NeoNeuro
    188
    Aug 4, 2014
    Panama City, FL
    Thanks everyone. I took another look at a Firebird hood in the fresh light of day and it's pretty obvious that it would be a lot more sheet metal work than I really want to get into. The fender lines are different and it has a peak down the middle. I'd be better off just cutting a Camaro hood, but that's what I was trying to avoid in the first place. Ah well, going to Emerald Coast Cruzin today. Maybe I'll get some new inspiration there. Thanks again.
