Tach doesn't work
Discussion in 'High Tech Retrofits' started by badazz81z28, Sep 27, 2017.
  1. badazz81z28
    16,597
    439
    Las Vegas, NV
    Using the LS7 GMPP harness, there is a tach output that the instructions state is a 2 pulse output. I set the tach to accept 2 pulse but nothing. I checked the wire continuity ands it's good. Checked for voltage, hard to check but something is there.
    How can I actually to see if the tach is working? All Worked fine before I pulled the LS1.
  2. badazz81z28
    16,597
    439
    Las Vegas, NV
    Btw, it's an Autometer ultra lite
  3. Goat
    1,905
    43
    Jun 7, 2001
    moncure, NC
    My instructions state that the signal is a low voltage square wave and some tachs may have a problem reading it. It talks about installing a 5k ohm/1/4 W resistor...
  4. badazz81z28
    16,597
    439
    Las Vegas, NV
    Why LS1 worked fine , that odd
  5. badazz81z28
    16,597
    439
    Las Vegas, NV
    Not much of a computer person...where do you buy resisters other then online?
  6. nobreaks254
    nobreaks254 Veteran Member
    493
    9
    Jul 14, 2007
    aberdeen, SD
    Radio shack
  7. CaliCamaro75
    CaliCamaro75 Veteran Member
    378
    23
    Sep 6, 2015
    Winchester,CA
    If radio shack is not around anymore. You could try computer repairs shops
  8. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
    I read that there are less than 50 stores left nationwide...makes it tough for little things like this. I really liked my local radio shack.
    Amazon Prime is a suggestion, 2 day shipping is probably the fastest other than a PC repair shop.
    Good luck
  9. Goat
    1,905
    43
    Jun 7, 2001
    moncure, NC
    From my instructions...
  10. badazz81z28
    16,597
    439
    Las Vegas, NV
    Another member have me different advice. Create a pin on J1 pin 24 and splice 24 with 25 (current tach out on J1). Worked!
    He told me pin 24 is already a pull up signal and he was right and no resister
