Tail pipes
Discussion in 'Engine Topic' started by johnnycamaroz, Dec 19, 2017.
  1. johnnycamaroz
    johnnycamaroz Member
    55
    Jul 22, 2014
    tucson,az
    my car came with no tail pipes just turn downs "too loud" for me
    I ordered walker pipes from RO i hope i can use them on the flow master set up it has.
    i know for sure the pipe is going to need to be expanded to 2-1/4 or 2 1/2 to fit into muffler.
  2. johnnycamaroz
    55
    Jul 22, 2014
    tucson,az
    her are the pipes as of now
  3. Smokey15
    Smokey15 Veteran Member
    3,208
    1,303
    Aug 13, 2017
    Caledonia, MI
    I installed 3" mandrel bent tailpipes on my '67 Skylark. "Mild" 464" Buick. Street driven. I did it so you can hear yourself think inside the car. My friend did exactly the same and it didn't slow his car down at the track at all.
  4. CorkyE
    10,532
    546
    Likely going to wind up taking it to a muffler shop and let them bend you some pipes. Hard to make stock pipes fit non stock type mufflers.
  5. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    Getting the pipes to go over the axle (OTA) is VERY expensive. I searched a LOT for OTA pipes, couldn't find 'em, just complete systems. To get the pipes bent by a muffle shop was about 450$. Up to 72 is a little easier because they exit out the back and travel on each side of the gas tank.
    Start checkin out wreckers.
  6. badazz81z28
    17,379
    604
    Alabama
    $450 is ridiculous. I had a complete system custom built for my car less then that. OP, call a few muffler/exhaust shops, I bet the tail pipes can be done for no more then a couple hundred.
  7. muscl car
    21,953
    792
    Jul 8, 2001
    High Desert of Hesperia Calif
    I had mandrel bent 3" tail pipes done at a local hi perf muffler shop for $90
  8. CorkyE
    10,532
    546
    I paid less than 1/2
    I paid less than 1/2 that for a complete system, from headers to out the back.
  9. Smokey15
    3,208
    1,303
    Aug 13, 2017
    Caledonia, MI
    Mine, through Finishline were over $400. And, we altered them.
  10. jbloake
    jbloake Veteran Member
    357
    85
    May 1, 2002
    Atlantic Canada
    Has anyone used Flow Master 815801 2 1/2" mandrel bent 409 stainless ?
