Taking off teflon tape
Discussion in 'Tips 'n' Tricks Topic' started by bourbon_scotch, Oct 31, 2016.
  1. bourbon_scotch
    1,950
    40
    Jan 10, 2003
    USA
    Yes this seems stupid but i've actually gone to my toolbox and gotten a small screwdriver to get into the threads and get the tape off. What should you do instead? Get any kind of sticky tape and wrap around it.
  2. APEowner
    APEowner Veteran Member
    640
    11
    Dec 9, 2013
    Albuquerque, NM
    Wire wheel on the bench grinder
    Kamikaze likes this.
  3. Twisted_Metal
    25,389
    330
    Small screwdriver or awl is what I would use.
    It's not like it's actually bonded to the metal.
  4. flint9
    flint9 Member
    70
    Jun 6, 2016
    st louis mo
    wire brush or wire wheel works best.its what we use at work.
  5. 80sz
    80sz Veteran Member
    2,241
    176
    Feb 2, 2014
    Buffalo,n.y.
    Air compressor works great, hit the threads wirh high pressure air and it rips it and you can wipe it off with out maring threads.
  6. bourbon_scotch
    1,950
    40
    Jan 10, 2003
    USA
    no... i'm actually saying try using masking or electrical or whatever kind of tape to grab on to it and it comes right off, that is if its not full of oil
  7. Coadster32
    1,219
    43
    Oct 2, 2013
    Milford,CT
    I think using tape might be difficult as the teflon tape forms itself to the threads. Regular tape won't form like the teflon will. Won't hurt to try it though.
  8. fester
    fester Veteran Member
    132
    9
    Jun 26, 2016
    Central Texas
    Just food for thought, In the industrial world(my jobs) Teflon tape is NEVER to be used on cast iron or aluminum. You have no "feel' as to how tight you are getting it and will crack the cast in most instances because the pipe threads are tapered. Also if you use it on instrument fittings make sure you don't wrap the first thread because it will wreak havoc with gauges, meters etc.
  9. bourbon_scotch
    1,950
    40
    Jan 10, 2003
    USA
    ya... i'm not saying to use other tape in place of teflon tape i'm saying if you ever need to take the teflon off the threads. Wow why did i even post this.
  10. Coadster32
    1,219
    43
    Oct 2, 2013
    Milford,CT
    I get it, and I thought the question was worth a shot, as I was following this thread. I meant that if you have telfon tape on a male thread, and want to get it off by using some other type of tape, the tape might not grab that well because the teflon tape would be into the threads better than any other type of tape, and may not "grab" the telfon enough to pull it off. I have never tried it myslef, as I also pick out the teflon which is a PITA.
    BTW...it looks like Dave Mustaine behind that guitar in your avatar....Rust in Peace is my fav. album by Megadeth.
