Tankless water heater
Discussion in 'The BS Topic' started by z2880, Nov 4, 2019.
  1. The Champ
    The Champ Veteran Member
    4,541
    547
    Sep 14, 2000
    MN
    Actually, a properly insulated water may provide you with enough hot/warm water for you to have your power restored before running out if you are prudent.
    A tankless has zero hot water available from the time you lose power til the time power is restored.
  2. 72'z'steve
    72'z'steve Veteran Member
    1,003
    109
    Oct 15, 2000
    waukesha wi usa
    I'm on a well,so when the power goes out,only water is what the pressure tank gives has/gives so its a few toilet flushes until the power comes on. LOL-Later Steve!!
  3. FreedomPenguin
    FreedomPenguin Veteran Member Lifetime Gold Member
    1,148
    59
    Sep 19, 2006
    Dayton, Ohio
    I have an water heater that works perfectly fine. but part of me wonders about tankless one day. If it isn't broke don't fix it type deal. I have myself, my gf and 2 room mates and we've never had cold water, so our set up is awesome. but if tankless can do same thing but remain more efficient I may consider.
    my water heater is like 15 years old too, so I am looking for replacements soon, or just get a newer/fancier more insulated traditional water heater.
  4. 73 Z
    941
    19
    Jun 9, 2007
    Los Angeles, Ca
    To clarify, a natural gas (with pilot light) thermo coupler type stat, will heat with no elec.
  5. Lowend
    14,972
    446
    Mar 25, 1999
    San Jose, CA, USA
    I can’t speak with personal authority. But I know several plumbers and they all recommend against tankless water heaters.
  6. ssupercoolss
    ssupercoolss Veteran Member
    748
    183
    Nov 3, 2015
    PA
    You could run a tankless gas one off of a pretty small inverter i bet, and of course, the smallest generator would run it as well.
    I have found so many different HVAC guys with split opinions about tankless hot water heaters and heat pumps. i know guys that swear by them, and guys that hate them. I am no HVAC guy, but i have both, and really like both, and the heat pump is in a pretty cold climate.
