Tanks Inc....
Discussion in 'High Tech Retrofits' started by grzewnicki, Aug 23, 2019.
  1. grzewnicki
    3,447
    175
    Dec 9, 2009
    Gordon from Jacksonville Fl
    Anyone ordering a kit from them...check your parts carefully. No parts list included (got tank, pump and sender), looked it over thought well that's weird no list of what supposed to be in here. Looked directions over kind of quick and then when assembling looking at pump diagram I'm like "what is this thing in the pic" oh yeah didn't get the filter sock for the bottom of the pump, Summit came through quick, one day part was there. After doing assmebly of components went to put pump in tank and where the hell is the wire harness, yup not there either. Called Tanks since I didn't thin SUmmit would have that part and they said I had to call Summit, got the part number and once again Summit came through. They didn't have a good reason fro not including a parts list, really $500 worth of parts and you can't tell me I am expecting to have in the box?
  2. xten
    xten Veteran Member
    3,082
    1,851
    Sep 24, 2014
    Pittsburgh, Pa.
    Strange they wouldn't include a list of what you were supposed to get or needed. If I order from Summit before 3:30 PM, I get the stuff the next day. Summit's got it together IMO.
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,388
    83
    Feb 2, 2008
    SF
    Yup that’s tanks for ya! I hope you don’t have any issues after the install because if you do your on your own with those guys. :/
  4. badazz81z28
    17,113
    550
    Las Vegas, NV
    Kind of why I complain about it...but pay more for Ricks Tanks. They come complete....
  5. 1979lsTA
    1979lsTA New Member
    22
    8
    Aug 14, 2019
    No issues with my order or the function of it, been going strong for a year and a half.
  6. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,021
    149
    Dec 19, 2008
    You have a PM
  7. QUAKE_WARS
    2,021
    149
    Dec 19, 2008
    I learned with everyone, Check your packages AS SOON AS THEY ARRIVE!!!!!!! Summit and jegs have done this to me MANY times..
  8. TCinthe6
    TCinthe6 Veteran Member
    128
    38
    Nov 5, 2017
    Toronto, Canada
    Part of the reason why I went with an Aeromotive tank. Pump and sending unit are pre-assembled...just figure out what fittings you want to go with along with some straps.
    I had to dimple my trunk to make a little room, but otherwise, everything works like a charm.
    You might save a couple bucks buying the parts individually from Tanks, but the cost savings and headache are not worth it in my opinion if you are looking for a complete system.
  9. Zoomin
    Zoomin Veteran Member
    102
    24
    Aug 5, 1999
    Oklahoma City, OK USA
    What wiring harness are you talking about? I've ordered five Tanks Inc tanks and never received a harness, but never needed one?
  10. grzewnicki
    3,447
    175
    Dec 9, 2009
    short harness that connects to pump and goes out through top of pump to connect to your ground and power source, just a black and red wire about 12 inches long.
