tbi in non tbi vehicles
Discussion in 'High Tech Retrofits' started by shawn81z, Feb 25, 2006.
  1. shawn81z
    shawn81z Veteran Member
    1,350
    Aug 12, 1999
    nanaimo, bc,canada
    Hey folks,
    I know this isnt "modern", but i was just wondering where i can find some info on installing a tbi engine in something that was originally carbed, or if anybody has some info they would like to share. I am interested mainly in fuel delivery and wiring. Thanks.
  2. EvolGrinZ
    EvolGrinZ Member Lifetime Gold Member
    57
    Feb 20, 2006
    Delft, The Netherlands
    What do you mean with TBI?
    I only know TDI......
  3. Knuckle Dragger
    14,736
    1,285
    Nov 2, 2002
    Waddell AZ
    Throtle Body Injection ;)
    try Jim at http://www.jimsperformance.com/
    Also down load Ultim8z's EFI guide. There is lots of good info there. I did a TPI swap and a lot of the stuff you'll run into will be the same feel free to ask anything specific. The swap should be fairly easy.
  4. patgizz
    patgizz Moderator Lifetime Gold Member
    12,737
    Apr 10, 1999
    Cleveland
    TBI is relatively simple. only needing 9-13psi to run helps. i'm sure you could modify a stock harness to work with a swap, or else harnesses are on ebay quite a bit that are basically a 2 wire hookup.
  5. EvolGrinZ
    57
    Feb 20, 2006
    I'm feeling a noob here.....whats tpi? Throttle Power Injection or something?
    And could you explain those 2 terms a bit more?
  6. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    TBI: Throttle Body Injection (More or less an electronic carb.)
    TPI: Tuned Port Injection (A version of Multi-port Fuel Injection with long "tuned" runners that optimizes low-end power.)
    TDI: Turbo Direct Injection also Tuned Direct Injection also Turbo Diesel, Impressive (Okay, so I made the last one up and the second one was only for one year or so.)
  7. BonzoHansen
    19,390
    760
    Jun 1, 2005
    Scott from Hamilton, NJ
    Holley makes a pretty nice TBI setup, from what I have read. You can use your 4bbl manifold.
  8. GoldenOne7710
    4,797
    397
    Jun 23, 2004
    Athens, GA
    I've done this project more than once. What would you like to know? You grab a computer from a TBI equipped vehicle. You decide on your compression, cam profile, exhaust, and vehicle use. Do you want to go fast, kinda fast, or HOLY poo fast? I can point you in any direction you want to go.
  9. EvolGrinZ
    57
    Feb 20, 2006
    Thanks for the explanation, makes clear now :)
    And btw, TDI does excists.
    I have a Seat Ibiza 1.9 TDI and its a diesel engine.
  10. ligtag
    ligtag New Member
    19
    Apr 11, 2004
    Concord,NH,USA
    I have a complete GM TBI set-up that I had installed on my 79 and changed out to a LT-1 motor instead. I have everything including the fuel pump and wiring harness. I have a couple of computers and extra chips. Most importantly I have collected a complete manual on all the to-do's. Email me for more info. Thanks Ligtag
