Testing 70 Year Old Motor Oil
Discussion in 'The BS Topic' started by 78TypeLTCamaro, Dec 6, 2019.
  1. 78TypeLTCamaro
    78TypeLTCamaro Veteran Member Gold Member
    496
    13
    Mar 2, 2001
    Waltham, MA. USA
  2. Shizzle
    Shizzle Veteran Member
    2,472
    504
    Aug 1, 2012
    oak lawn, illinois
    It was old oil, but did they list liters on oil containers in the 50’s?
    I’m thinking it was more 70’s.
    I’m sure Blackstone got a kick out of testing that stuff.
  3. Gary S
    22,583
    807
    There doesn't seem to be any doubt that oils have improved over the years. Now, I'd like to see a similar test using a modern full synthetic oil compared to the modern petroleum oil. It would be interesting to see if there are any significant differences.
  4. Jimmac
    Jimmac Veteran Member
    374
    69
    Dec 24, 2013
    tucson az
    so there really is t any harm to collect old oil cans at yard sales and use the oil for breaking in flat tappet cams. heck you fire it up, run it for a bit and dump it anyway. jim
  5. Gary S
    22,583
    807
    There probably isn't much oil of that age left in existence today. That can wasn't even marked as a multigrade oil on the can, so it probably predates the 10W-30 and 5W-30 oils made later. Even a multigrade oil from the 70s and 80s should perform better than those old straight grade oils did so any multigrade oil would probably work for breakin as long as you ran it only a short time.
  6. ol' grouch
    ol' grouch Veteran Member
    2,973
    823
    Jul 4, 2013
    Evansville, In.
    That can looks like some cans I've got laying around from the 70's. The bulk oil we used when I drove a truck were the same color green. I don't recall any multi-weights until the mid 70's. You can still get non-detergent oil. You have to hunt, but it's out there. It's used in air compressors and the like. Pretty good test though. Maybe not on a par with what the oil companies have, but still pretty good.
  7. The Champ
    The Champ Veteran Member
    4,620
    571
    Sep 14, 2000
    MN
    I did my first oil change on my first car, a 1960 Pontiac Bonneville, in the summer of 1971. Used Havoline 10W30...
    The factory owner's manual for my 1964 GTO and my wife's '72 Camaro both list straight grade and multi viscosity oil options.
    Back in 2010 I started working for an ACDelco warehouse distributor that handled a "house brand" oil by the name of Pronto. Pronto was packaged by the Amalie Oil Company. I learned that Amalie Oil introduced the first multi viscosity oil:
    http://www.amalie.com/About-Us
  8. Gary S
    22,583
    807
    When I grew up on a farm in the 50s, my Dad had a 30 gallon drum of straight weight 30 oil that we used in the tractors and trucks. The only vehicle that got multigrade oil was the car. We had a 15 gallon drum of 5W-20 for it. The 30 weight oil barely poured out of the barrel when the temps in Winter dropped down to -30 or -40. The multigrade 5W-20 was much better in the cold.
  9. budro6968
    budro6968 Veteran Member
    3,269
    522
    Apr 2, 2016
    Jax Florida
    This guy on project farm does all kinds of crazy tests with oil and everything else. He is very good at what he does. I like the lawnmower engine stuff. JB weld on a connecting rod even a head made from it.
  10. G72Zed
    G72Zed Veteran Member
    1,192
    275
    Sep 8, 2015
    Um, yes there is. Unless you like changing FT cams.
