TH350 Broken bellhousing
Discussion in 'Transmission & Driveline Topics' started by f-body, Jun 9, 2009.
  1. f-body
    f-body Veteran Member
    1,674
    Feb 1, 2000
    Dallas
    What could cause a crack in the bellhousing in a TH30 auto. Its almost cracked all the way around about 75% of the bellhousing and its cracked all the way through. I did it at the track in the 1/8 mile. I have a 3500rpm stall converter and the car ran slow. It launched good and I got told last time I had a tranny leak. Climbed under the car and found the crack in the bellhousing.
    I have polyurethane engine mounts and tranny mount.
  2. rscamaro73
    rscamaro73 Administrator Staff Member
    Prolly that poly trans mount. They've been known to break trans mounts and bellhousings due to no 'give' in the driveline under Tq.
    Stock trans bushings work well for any street/strip car.
  3. 383CamaroZ28
    383CamaroZ28 Veteran Member
    th350 casings are very weak and prone to cracking
    poly mounts don't help but I don't believe they are completely to blame. If its gonna break than its gonna break.
    I have run a solid mount on mine for the past 6 years without any problems (knock on wood) on a stock case
  4. Cardinal
    8,191
    Jun 22, 2003
    Endicott, NY
    Any drive line shock can split the bell housing on a TH350 if a solid trans mount is used. I'm not sure about the poly mounts but it may not be flexable enough which could break the bell housing. We always use the old origianal rubber trans mounts for that reason.
    As for the broken bell, replace it with the JW Perfomance SFI approved bell housing ( http://www.jegs.com/i/J+W+Performance/564/92452/10002/-1 ).
  5. Dukes72
    Dukes72 Veteran Member
    440
    Mar 14, 2008
    Central IA
    I would venture out to say that in front of the crack it is trying to twist more or less than the trans behind the track. Could be broken or weak motor mounts or similar issue with the trans mount.
  6. f-body
    1,674
    Feb 1, 2000
    Dallas
    Well All the mounts were replaced at the same time. Energy suspension engine mounts clamshell style and trans mount. All are less than a 2 years old and if they have 4000 miles on them I would be suprised.
    I do have a spare trans case that I can swap internals from this one to other. I will swap the poly trans mount for a new rubber one and use a limit strap to keep the strain of the trans case.
    I might install the new bellhousing from jegs.
  7. f-body
    1,674
    Feb 1, 2000
    Dallas
    Not sure if I mentioned before but the crack is about 3/4 of the way around the bellhousing. No wonder it makes noise at about 3000rpm. at least it works well enought to get the car on the trailer.
    Well I got my new Th350 trans from Jakeshoe. Now all i need to do is get it installed. I will take some pics of the cracked beelhousing and put them on photobucket when I get the cracked case out.
    And yes i will be changing the poly mount to a stock rubber one.
    I did start removing the trans on superbowl sunday but was interupted when i slipped and my finger caught on of those scres on the driver side firewall. Sliced the finger open and had to go and get some stiches. All better now. All I need to do is get the trans swapped out and I can drive the car again.
  8. mrdragster1970
    I would look more at the engine moving. I ran with slicks with poly poly before going with solid motor mounts.
    Maybe even use elephant ears for track only outings. I ran 10.20's with a 350 and never cracked anything,
    but I clamped down the engine.
  9. BonzoHansen
    I've seen a few broken over the years. I have one in the back yard right now.
  10. f-body
    1,674
    Feb 1, 2000
    Dallas
    Here is the photobucket link to the pics. check them all out.
    http://s200.photobucket.com/albums/...otos/?action=view&current=crackedtrans002.jpg
    there are 16 of them. the crack extends from driver side along bellhousing and then there is one by the driver side bolt holes that mount trans to engine.
    I could bend the big part to separate the crack. Inside the bellhousing too. At least it held long enought for me to get it on the trailer. Cracked in like 6 places.
    Putting the Jakeshoe TH350 manual special in tomorrow!!!
