The Warhawk - LS7 engine block and heads
Discussion in 'High Tech Retrofits' started by Aceshigh, Aug 9, 2006.
  1. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    I guess these just came out, from the sounds of LS1tech and the Corvette forums ,
    there is a BUNCH of buzz around them being built for high boost applications.
    http://forums.corvetteforum.com/showthread.php?t=1382207
    http://www.ls1tech.com/forums/showthread.php?t=548277
    Figured if anyone wanted something like this, they could check it out.
    [​IMG] $3,999 per block....ouch!!!
  2. rscamaro73
    rscamaro73 Administrator Staff Member
    14,966
    9
    May 30, 1999
    Striking fear and destroying the enemy
    So what's the potential ?
    I'd prolly be pretty safe to say with a properly built professional engine....with an ungodly amount of boost.....over 1000hp will be the NORM.....
    That thing is sick....almost makes me.....nah......:crazy:
  3. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    1,663
    59
    Oct 1, 2004
    Montreal (Living in Houston)
    Dark Side? What dark side? We don't need no stinking dark side
  4. onovakind67
    onovakind67 Veteran Member
    4,661
    Jul 8, 2001
    Fairfield, CA
    I'm still looking for the 6th bolt....
  5. Patrick73RS
    1,663
    59
    Oct 1, 2004
    The sixth bolt would be down in the lifter valley. This must be xome sort of casting test block or something. There are no provisions for cooling.
    Ha I just went and read the thread in the link posted. It is a test block for mock-up.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    :screwup:
    What's that mean ?? Mock up ??
  7. jakeshoe
    8,883
    21
    Dec 8, 2000
    Republic of Texas
    It in the lifter valley, you can see it on the far bank inside. Like the old ZL1 style blocks.
  8. ZedMan
    ZedMan Veteran Member
    178
    Dec 15, 2004
    Calgary, AB, CA
  9. rscamaro73
    14,966
    9
    May 30, 1999
    Ouch that's tight....
  10. Patrick73RS
    1,663
    59
    Oct 1, 2004
    They are using that block to mock-up parts and to ensure that everything fits the way that it should. That block shown in your picture can't run as an engine. They are going to be checking that all of the things (such as heads) bolt up correctly and the fitting is to their liking.
    Look at this block and you can see the collant passages
