The Warhawk - LS7 engine block and heads
Discussion in 'High Tech Retrofits' started by Aceshigh, Aug 9, 2006.
  1. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Okay, so meaning that's the prototype block for testing. Gotcha.
    I know they are accepting orders and it's $4K for a block plus heads.
    It just sounded pretty heavy duty so I figured I'd post it for the hardcore boost enthusiasts. ;)
  2. Patrick73RS
    Patrick73RS Veteran Member Lifetime Gold Member
    1,663
    59
    Oct 1, 2004
    Montreal (Living in Houston)
    Well for the guys that like the boost this will be the one to have! I would like to see what GM comes out with as they are working on an LSx style unit as well.
    Katech has some seriously sick engine packages.
    At one point I considered dropping my car off to them and just having them do all of the conversion. $$$$$$$$$$$$$$$$$$$$$$$
  3. CTSmechanic
    CTSmechanic Veteran Member
    490
    Jan 2, 2004
    North Carolina
    I think the aftermarket is going to get some hurt put on them by GM.. Unless your a boosted application and need the 6 bolt heads I think the L92 heads and spider manifold or the plastic LS style will be the set up of choice for many N/A as well as some power adder cars.The L92 heads flow almost like a GM 18 Deg and are 800 buicks a set assembled..Soon as I get back on my feet and have some money to spen Im lookin at a L92 top end with a D-1 for the old firechicken...
  4. DirtyScotty
    DirtyScotty Veteran Member
    814
    Jan 27, 2004
    Caledonia. Ont. Communist Canada
    Shouldnt be long before I am diving into one of those Warhawks. I cant wait!
    Should cure alot of head gasket problems with power adders. I cant help but think I will have to sell me 413 small block and get either an LS2 sleeved block or if at that time the money permits go the full bore and get the Warhawk. Wouldnt that be cool in a second gen:eek:
  5. Dirt Reynolds
    Dirt Reynolds Veteran Member Lifetime Gold Member
    3,625
    Jan 17, 2003
    BC, Canada
    Check out the new Oct '06 Chevy High Performance. GM is sponsoring Robin Lawrence (of 5.0 Mustang fame) with an LSx - powered Nova. The engine will be 454ci and use LS7 heads to make 900HP naturally aspirated.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    ^ ^ ^DAMN!!!! :confused: :eek:
  7. Dirt Reynolds
    3,625
    Jan 17, 2003
    BC, Canada
    Yeah -- pretty shocking isn't it. :eek:
  8. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    If you want to see the future in blocks do a search on the GM ROX block. That is the trick block of the year.
  9. Dirt Reynolds
    3,625
    Jan 17, 2003
    BC, Canada
    The ROX blocks are in the '06 GMPP catalogue.
  10. Rick WI
    10,400
    Jul 9, 2001
    Madison, WI
    They rock, I want one of them plus one pair of SB 2.2's. Then about another 20 thou so I could trick it out and then break the dyno with it. 4.5 bore centers, symetrical ports, dual pin oilers, side water cooling passages. Let's rock! That is a block that can take the boost and not frag a head gasket.
