This made me chuckle and think of this site when I read it...
Discussion in 'The BS Topic' started by Joekool, Dec 11, 2012.
  1. John Wright
    14,637
    198
    Aug 9, 2002
    Rustburg, Va
    Has 165K+ on the clock now.
  2. camarochevy1970
    camarochevy1970 Veteran Member
    7,766
    46
    Jan 23, 2003
    Pittsburgh, PA
    probably something minor then, if only come on a few times over the last couple years.
  3. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    5hanks RON. I will check the harness further
  4. Joekool
    Joekool Veteran Member
    5,919
    35
    Feb 4, 2002
    Hollister CA USA
    Check the ECT sensor (coolant temp sensor) they can sometimes cause an IAT code to set do to the fact that when the engine is cold both sensors should read about the same temp. If they dont, throwing an IAT code seems to be the default sensor to label as bad by the PCM (dont ask why because engineers do different drugs then the rest of us :D).
  5. 91chevywt
    91chevywt Veteran Member
    206
    May 27, 2008
    South Jersey, NJ
    "...monitors the amount of unburned oxygen in the exhaust..."
    Oxygen doesn't burn
  6. Earlsfat
    Earlsfat Veteran Member Lifetime Gold Member
    1,538
    19
    Jun 14, 2006
    Whut?
    A 1/2" square of black electrical tape will do the trick.... cost, about .01ยข :)
