Thoughts on a TKO in a 70 RS 396
Discussion in 'High Tech Retrofits' started by ZoSoIV, Oct 25, 2018.
  1. ZoSoIV
    ZoSoIV New Member
    22
    Sep 16, 2018
    ... I have a 1970 Z/28 RS 396 mild cam 3.73 12 bolt pos rear end with M22 4 speed ...I’m taching 3 grand or more at 70mph ... needs a new clutch so thinking the TKO 600 is my best option for a drop in , opinions, options , what can I expect rpm wise at 70-75 mph and current prices ?
  2. BonzoHansen
    19,503
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    An overdrive transmission is the best thing in the world you can do for a car did you drive a lot . Sites like bowler transmissions have rpm calculators you can punch in speed, tire od and gearing to see rpm.
    PS I made this its own thread instead of bumping an 8 year old thread that was about a different transmission
    ZoSoIV likes this.
  3. camarochevy1970
    camarochevy1970 Veteran Member
    7,816
    63
    Jan 23, 2003
    Pittsburgh, PA
    I think Scott was trying to say an overdrive transmission is the best thing you can do for a car you drive. Not sure what happened though LOL
  4. BonzoHansen
    19,503
    824
    Jun 1, 2005
    Stupid voice to text lol
  5. 71RS/SS396
    71RS/SS396 Veteran Member
    2,627
    31
    Aug 26, 2008
    Wake Forest NC
    You need the Jersey version so it understands you.... :crazy::crazy::crazy:
    Knuckle Dragger likes this.
  6. BonzoHansen
    19,503
    824
    Jun 1, 2005
    I think that's freaking right! yo
  7. Richard Schultz
    Richard Schultz Veteran Member
    294
    29
    Oct 8, 2018
    Green River Wy
    Try a taller tire on the back,if you dont like it run a over drive tranny,or a taller rear gear,just depends on what your looking for.
  8. Scaleytail
    Scaleytail Member
    82
    13
    Jun 12, 2016
    North Aurora, il
    The Tremac site has a RPM calculator. Make sure you match your engines RPM range to all gears including OD.
  9. Cooldawg
    Cooldawg Veteran Member
    196
    11
    Jun 3, 2014
    Angola, IN
    I looked at TKO as well, but I’m going with M23Z Muncie (or autogear) with 3.08 or 3.23’s in the rear. The Z will allow me to use my existing clutch, shifter, and crossmember...
  10. flht99b
    flht99b Veteran Member
    317
    57
    Nov 28, 2014
    Knoxville, TN
    I currently have a TKO600 5 speed in my 71 Z28. 4.10 gears, 28" diameter rear tires and 5th gear in trans is .64 ratio. I turn ~ 2200 at 70mph.
    redriderjf87, Scaleytail and joselk1 like this.
