Thoughts on replacement headliner. ABS of fix old board?
Discussion in 'Interior Restoration' started by 75Motion, Aug 23, 2019.
  1. 75Motion
    75Motion Veteran Member
    355
    Jan 26, 2008
    Ohio
    My 75 has the usual dropping headliner. It has been fixed previously but has fallen again. I could replace the entire thing with a new one ready to install but the only ones I find use ABS under the fabric. The old "board" is still usable and not too bad. I would have to get new fabric and glue it down. What problems are there with the ABS. I'm seeing mixed reviews on them.
  2. 77thor
    77thor Veteran Member Lifetime Gold Member
    2,495
    12
    Mar 22, 2002
    Milwaukee, WI USA
    I put an ABS board in my 77 years ago... Never had an issue.
    Great product, IMO.
  3. 73LT
    73LT Veteran Member
    277
    Jun 9, 2002
    PA, USA
    I had the same problem with my '73 years ago. The upholstery shop removed the headliner board. Then they removed the remaining foam and used a DA to remove most of the glue. It was then recovered with Madrid grain vinyl to match the seats. Looks great.
  4. 351maverick
    351maverick Veteran Member
    3,593
    383
    Aug 11, 2010
    erie, PA
    or remove it completely & leave it off
  5. Plater Tom
    Plater Tom Veteran Member
    1,372
    21
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    That is what I did also. Still looks fine. Tom
  6. Twisted_Metal
    26,820
    877
    I've recovered my old cardboard panel twice since I've owned my Camaro.
    It's not that difficult if the board isn't creased or torn.
    Spot putty can be used to fill any dents and tears can be taped on the back side.
    If any repairs are required... The surface you're recovering needs to be smooth to get the fabric/vinyl to lay down nice.
    There are a couple of different ABS panels out there for sale and some of them don't fit right.
    You want something which is properly molded and not just a flat plastic sheet.
    manicmechanic likes this.
  7. xten
    xten Veteran Member
    2,662
    1,450
    Sep 24, 2014
    Pittsburgh, Pa.
  8. BonzoHansen
    19,302
    703
    Jun 1, 2005
    Scott from Hamilton, NJ
    The abs one worked well for me...
    ....Lol until i had to remove it because i needed maximum headroom with my helmet. My seats are too high. Gonna to remedy that this winter
  9. 75Motion
    355
    Jan 26, 2008
    Ohio
  10. BonzoHansen
    19,302
    703
    Jun 1, 2005
    Why would you send it back? Did you have install issues?
