Thoughts on replacement headliner. ABS of fix old board?
Discussion in 'Interior Restoration' started by 75Motion, Aug 23, 2019.
  1. 75Motion
    75Motion Veteran Member
    355
    Jan 26, 2008
    Ohio
    It seems flimsy. It will require more than one set of hands to install as it's very flexible.The old one I could use the center overhead light to hold it up and then go around and put the rest in place. Unsure it it will stay up where it should. I haven't taken it out of the plastic yet in case I need to send it back and just buy the correct material to use on my old backer board.
  2. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,787
    94
    Aug 18, 2003
    On Wisconsin!
    my original board was damaged in the fire, so I went with the older bow style replacement headliner... I am happy with the way it turned out
  3. CDesperado
    3,534
    53
    Oct 1, 2004
    Dallas Texas
    The ABS board I got from Classic Industries didnt fit well - it was about 3/4 too short in the back. (This was from 2011, they may have changed things since then.)
    I opted to buy a formed headliner board from Stock Interiors, which is probably a few pounds lighter than the CI one.
  4. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    If you go the ABS route, be sure to research what you're buying and try not to get burned like I did. There are basically 2 types of ABS headliners out there, flat and formed. The flat ones will not fit. I think most of those are off the market now, but it's worth your time to check. The flat one I got looks like CDesperado's picture except it doesn't have any of the notches and holes on the sides, no visor holes, and is completely flat. I could overcome all of that except for the flatness. The ABS would not bend enough to fit the curves on the sides of the roof. It ended up being a really nice looking piece of junk.
  5. 2000SS
    2000SS Member
    53
    Jul 9, 2009
    Ohio
    I've done this on a few cars....
    Sand all the foam and crap from board. Go to fabric store and buy felt that matches interior color. Glue on with 3M contact adhesive. Remember, spray both sides and let set till tacky before mating.
    Not stock look, more modern. Cheap and you'll never have a problem again. No foam to disintegrate and looks really good.
  6. Knucklehead
    Knucklehead Member
    67
    15
    Nov 6, 2008
    Washington, DC
    I had the same experience as Twisted Metal. The headliner on my 77 started sagging after about 12 years. Bought correct headliner material and re-glued it to the original cardboard. It looked original and very nice. But it began sagging after about 15 years. It's the foam backing that disintegrates, not the glue. Ended up selling the car with a sagging headliner. Also had a similar experience with an 89 Camaro. This time I bought an ABS headliner from Classic. Was worried when it came rolled up, but it fit fine and has lasted much better than the foam-on-cardboard OEM units. Depends on whether you want to stay original or not.
  7. manicmechanic
    manicmechanic Veteran Member Lifetime Gold Member
    2,117
    Oct 24, 2000
    Tulsa, Oklahoma
    How long ago did you get this and have you installed it? It is ABS and not a board/Cardboard piece?
  8. 75Motion
    355
    Jan 26, 2008
    Ohio
    I bought mine a couple of weeks ago. It's the flat ABS. The catalog didn't specify what type of material it was. I will have to check to see if it's the same size as the original as I still have it.
  9. 80sz
    80sz Veteran Member
    3,155
    415
    Feb 2, 2014
    Buffalo,n.y.
    I got a abs one also that is working good
  10. CDesperado
    3,534
    53
    Oct 1, 2004
    Dallas Texas
    I installed it about a month ago. It is ABS plastic, but slightly thinner than the flat one I bought from Classic Industries. (I bought the CI one back around 2011 or 2012. I bought the new one from Stock Interiors about 2 months ago.)
