Thread sizes
Discussion in 'Engine Topic' started by KHE, Apr 20, 2016.
  1. KHE
    KHE New Member
    Oct 16, 2015
    Hi everyone. Can someone please tell me what thread sizes are used for the intake bolts, water pump bolts, power steering bolts, and alternator bolts? I have a 70s 350 factory block
  2. grzewnicki
    3,461
    185
    Dec 9, 2009
    Gordon from Jacksonville Fl
    All those are 3/8-16
  3. 77 cruiser
    77 cruiser Veteran Member
    547
    25
    Nov 17, 2006
    Frostbite Falls MN
    Don't use too long of bolts for the intake, a couple of them will hit the pushrods.
  4. KHE
    KHE New Member
    Oct 16, 2015
    Thanks once again. NastyZ28 is the best forum ever.
    Does anyone know what tap to use on the valve cover bolts?
    Getting closer. Will post progress on the project shortly
  5. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    Are you re-threading or just cleaning ("chasing") the valve cover bolt holes?
    http://www.hotrodders.com/forum/thread-chaser-vs-tap-163154.html
    http://www.route66hotrodhigh.com/SBC-Bolts.html
    Item Description Size Qty
    1. Intake Manifold 3/8-16 x 1" 12
    2. Valve Covers (Pre-82) 1/2-20 x 3/4" 8
    3. Oil Pan 1/4-20 x 1/2" 14
    4. Oil Pan 5/16-18 x 3/4" 4
    5. Flywheel flex-plate 7/16-20 x 11/16" (3/4") ?
    6. Timing Cover 1/4-20 x 1/2" 10
    7. Torque Converter 3/8-24 x 1/2" 3
    8. Fuel pump 3/8-16 x 1 1/4" 2
    9. Thermostat housing 3/8-16 x 1" 2
    10. Carburetor 5/16-18 x 1 1/2" 4
    11. Water pump (have to measure them) 4
  6. fatkid_racing
    fatkid_racing Veteran Member Lifetime Gold Member
    1,049
    90
    Sep 21, 2005
    Saginaw Texas
    I think the size listed for valve covers is incorrect, I've never seen an 1/2" valve cover bolt.
