Throwing belts/ alignment question
Discussion in 'Engine Topic' started by rocket dawg, Aug 11, 2019.
  1. jeff swisher
    jeff swisher Veteran Member
    1,200
    352
    Apr 26, 2018
    Yukon Oklahoma
    Watch this video it may give you some ideas. It is a Laser belt alignment tool.
    There are a few different kinds out there on the market but they are EXPENSIVE!
    You could probably make your own with an inexpensive line and point laser level.
  2. rocket dawg
    rocket dawg Veteran Member
    315
    23
    May 5, 2015
    Grand Rapids Mi
    I managed to get them lined up with the straight edge, even on the bottom side. Test drive and all seems good and the belts are still tight. After some thinking, I do have the Pontiac bracket on the power steering pump. I never pulled the pulley off the pump to put the Chevy bracket on. The alternator brackets are Chevy for sure, Pontiac puts the alt on the drivers side. Next is putting the A/C back on the car. I have all of those brackets, but not sure if they will clear my taller valve covers. Again, Pontiac put the A/C on the passenger side so I removed it temporarily ( 15 years ago, lol)
  3. ssupercoolss
    ssupercoolss Veteran Member
    700
    165
    Nov 3, 2015
    PA
    To look at the belts on my Monte Carlo, it looks like things are in a different zip code as far as being lined up. Hold a straight edge, and things are lined up. I no longer try to "eye ball" things.
