Tiny Burn Throughs-Do I Need to Epoxy Prime?
Discussion in 'Body Restoration' started by MotionClone, Mar 8, 2015.
  1. MotionClone
    MotionClone Veteran Member
    1,471
    282
    Jan 20, 2014
    away from the crazies
    After sanding most of the Slick Sand off I ended up with a handful of burn throughs down to bare metal. The largest spot is about an inch long and 1/8" wide.
    Do I need to epoxy prime these spots or will my next step of primer/surfacer be sufficient?
    Couple spots to the right of rear marker light:
  2. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    being an 1" long I would re-spray with epoxy primer to be safe. I had the same thing happen but the spots were less than a pencil eraser and Barry @ SPI said I could just spray 2k over those. If it was me I'd go ahead and do one coat of epoxy primer and then do 2k over that. But I am more risk averse than most people.
  3. MotionClone
    1,471
    282
    Jan 20, 2014
    lol thought thats what you would say. I have no problem spot priming the bare spots. Its the additional sanding to feather those spot primes out I was hoping to avoid. I probably have 15 or so spots like the ones pictured.
    Im out of SPI and now using Omni Epoxy which doesnt sand as well at all
  4. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    Rule of thumb I use is if bigger than a quarter I spot with epoxy. If not primer surfacer.
  5. Rustbucket350
    Rustbucket350 Veteran Member
    841
    34
    Sep 4, 2013
    Oviedo, Florida
    You could always use a DTM urethane primer.
  6. Paint Fumes
    Paint Fumes Veteran Member
    488
    Aug 22, 2004
    Rick beat me to it but this is what I go with too.
  7. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    Surface prime it and move forward.
  8. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    bigger than a quarter in which direction? It's spots like OP's that would throw me off since they are relatively large in one direction but not the other. Know what I'm saying?
  9. Rick WI
    10,400
    Jul 9, 2001
    Madison, WI
    Surface area is what you gauge. Those spots can be primered. It will bridge without an issue.
  10. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    collision blast
    Go to the Collision Blast DIY site. Donny just did a vid on epoxy vs S/P
    He is emphatic that S/P is not a substitute for epoxy primer and that moisture will penetrate S/P and eventually bubbles will appear.
    But hey! What do I know?
