Tire Crib's...For that lift you need...
Discussion in 'Tips 'n' Tricks Topic' started by RockerMomsHotwheels, Jan 11, 2011.
  1. dwright406
    dwright406 Veteran Member
    3,843
    Jul 26, 2004
    Lake Jackson Tx
    I built an identical set last year.
    This is the best way to get the car up high enough to do a tranny swap if you don't have a lift.
    Good Job!
  2. masparks
    masparks Veteran Member Lifetime Gold Member
    1,594
    Nov 7, 2006
    Gas, Kansas
    Very cool idea!
  3. 5spd540
    12,397
    16
    Sep 19, 2009
    Guyton, GA
    Good work guys
  4. RockerMomsHotwheels
    RockerMomsHotwheels Veteran Member
    721
    Jan 14, 2007
    Our King's Ranch... Fredericksburg Texas
    Well I finally got my "Wrench" on today...I installed the B&M Shifter I got from one of you guys...Its been so long I cant remember who...Man was it nice working under the car with all that room...I can even work on my side...If you need to work under your car, build some of these things...They're great....
  5. kstripes
    kstripes Veteran Member Lifetime Gold Member
    512
    Mar 4, 2005
    Margate,FL,USA
    If you don't mind I'll steal your idea and use the wood right on the ground. I built a platform for my portable garage a couple of years ago and it rotted out anyway. That's been keeping me from working on my '79 Z28. I gotta take advantage of the nice "cool" weather and no hurricanes.;). I'm also gonna build me some of those to change trunk floor, thanks.
  6. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    You might need a better jack, both of mine will raise the car 19 - 20 inches.
    The low profile is a 2 ton and have had it 5 years and the standard height is a 3.5 ton, new this week. Using 6 ton jack stands the car can be placed fairly high.
    I like the tire crib concept and may build some, already have the wood and screws.
  7. 3SLO5
    3SLO5 Veteran Member Lifetime Gold Member
    3,639
    Jan 7, 2001
    Edison NJ USA
    i got them too they work for everything .
  8. nicks78camaro
    nicks78camaro Veteran Member
    863
    Apr 3, 2010
    Pittsburgh
    I wanna build a set of these, they could even hold a rear end up!
  9. Twisted_Metal
    27,290
    1,122
    They are gravity proof! :D
    They were used by ancient peoples to raise Stonehenge, the Acropolis and the great pyramids of Giza too. ;)
  10. arick793
    arick793 Veteran Member
    1,127
    Oct 27, 2008
    Rochester, NY
    I've got a bunch of 4x4's to get rid of, so I'm going to make the base out of 4x4's with 2x4's on top of that. I'm also thinking about putting caster wheels on the bottoms to roll the car around. Do you think it will be solid enough to mount wheels to?
