Tire Crib's...For that lift you need...
Discussion in 'Tips 'n' Tricks Topic' started by RockerMomsHotwheels, Jan 11, 2011.
  1. evilbeef54
    evilbeef54 Veteran Member
    393
    Jun 30, 2006
    Sailing down below
    im not so sure about the idea of rolling it around as the are all seperate, it seems like a rock of seam in the cement or something catching one of the wheels on one corner after you have momentum going... could spell disaster... not sure maybe not but i dont want to test it with my projects, i LOVE the idea of the stands though, i will probably be doing some soon when i start on the body work on the truck
  2. jerhofer
    jerhofer Veteran Member
    490
    Jun 4, 2009
    Rockwell, NC
    I retired after 38 years in the manufactured housing industry. We built identical stands such as these to support the homes at trade shows. We placed them under the steel frame rails about eight feet apart. We just built them a little higher than yours so that we did not have to remove the running gear under the homes for the show. We built them out of scrap lumber.
    Worked great on level concrete surfaces. I hadn't thought about using them on a car. Great idea.
  3. WheelerCamaro
    WheelerCamaro New Member
    26
    May 7, 2011
    Ogden, Utah
    Instead of buying...
    I am going to build a set of these based on the directions I found here. Thank you to all who have submitted info.
    I also wanted to share an idea that I had... Instead of buying new 2x4's and cutting them up, I found a local truss manufacturer and the let me take all the scrap 2x4's I wanted for free. A lot of what I got is well over 16" long.
  4. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    I built a set of these last winter for the TKO swap. Only difference was that I used a dallop of liquid nails between each board along with the deck screws. Solid as a rock!
  5. DAWG
    DAWG Veteran Member
    182
    Mar 30, 2008
    Colebrook, Connecticut
    nice but I have no need for that
  6. mickstan
    927
    Jun 11, 2012
    E'ville, IL
    ^^^^But you do have a need for a maid!
  7. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    Did the same on mine, was able to remove my grenaded TH400 while up on the cribs and reinstall the new trans.
  8. dcozzi
    dcozzi Veteran Member
    3,262
    513
    May 1, 2002
    Phoenix, AZ
    The cheap HF ones will get the car pretty high off the ground.
    I do like the cribs and built a set of those too. I mean, what happens if I have the Camaro in the air and need to use the jackstands on the truck, right?
    Is 8 layers some kind of standard? Mine have 9. I guess I do not know when to quit stacking the 2X4s. I also glued the wood together in addition to the screws as a safety paranoia thing. The biggest thing I could think of safety wise is to make sure the tire you have resting on it sits down in the hole enough to "chock" the wheel fairly well. My tire touches the second 2X4 down. 12" and 16" must be the perfect standard because, I put the 2X4s on the ground in front of and behind the tire and used a measurement that moved them together a bit. Mine came out 12" X 16" too. Drop the tires to 15-20psi and the car won't go anywhere while you work on it.
    I'm glad this got a writeup. These things can be used for just about anything and are tough. Like building blocks for big kids. I feel like an idiot though for not just going to a construction site in framing stage and raiding the dumpster. I paid for the wood. Not a sound DIY move on my part.
  9. twood
    twood Veteran Member
    330
    Feb 3, 2012
    Glen Morris, ON Canada
    Heres mine
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    Love em
  10. DAWG
    DAWG Veteran Member
    182
    Mar 30, 2008
    hell no Its a working shop, cleanup is at end of day!LOL
