Tire Crib's...For that lift you need...
Discussion in 'Tips 'n' Tricks Topic' started by RockerMomsHotwheels, Jan 11, 2011.
  1. gthmcty1
    gthmcty1 New Member
    15
    Feb 1, 2010
    Fontana, Ca
    LMFAO!!!!......NO CLEANUP it's only going to get dirty again ....our cars are never done!!!
  2. anderson8687
    anderson8687 Veteran Member
    121
    Sep 4, 2011
    Maine
    Noticed the "parking for FINNS only".....FINN POWA!
  3. camaro73lt
    camaro73lt Veteran Member
    927
    Feb 6, 2003
    Hanover, PA
    Hey guys, maybe I'm missing something after reading this entire thread but, seriously - how do you get the car up on these stands? What's the magic process? Thanks!
  4. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    It IS a magic trick! For me it is a multi step process as my floor jack only lifts to 20 inches and it is rated at 2 tons.
    1. Lift the front(under the crossmember) as high as possible and place jack stands under it.
    2. Move to the back and do the same thing(under the differential) with a second set of jack stands under the axle.
    3. Go back to the front and place a 4x4 block on the jack and lift again. This should lift high enough to get the blocks under the tires.
    4. Go to the rear again and repeat.
    5. Getting the car down is the reverse of the above steps.
    It is a scary situation getting the car up and down, especially the first time you do it. I always have a helper with me just in case something goes horribly wrong.
  5. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    Thats how I did mine and yes its a little scary at first. I ended buying a jack with a taller heigth limit and didnt have to use boards anymore. But I can not jack one end up and just put the cribs on, its to steep, you still have to do it in 5 steps like listed above.
  6. camarogasm
    camarogasm Member
    32
    Jan 21, 2011
    Harrah, Oklahoma
    Just built my set yesterday! Love this site! Now I can tighten up the suspension mods!
  7. SMCZ28
    SMCZ28 Veteran Member
    818
    Jun 15, 2010
    United States
    I see a lot of people building them but no one asking how much it costs to make them so.... how much does it cost in total to make these?
  8. FRANKP74Z
    FRANKP74Z Veteran Member
    140
    Jun 13, 2009
    Sayreville, New Jersey
    I glued & screwed the ones I made and with the 2 X 4's about $20 a wheel! If you had to buy everything. I get scrap wood / damaged pallets at work had screws from a left over deck project so just the liquid nails!
  9. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    My total if I remember correctly was about $75. Thats 16 feet of boards, 1 tube of liquid nails and a box of deck screws
  10. SMCZ28
    818
    Jun 15, 2010
    United States
    That isn't bad considering people are asking 200 freaking dollars for just a pair.
