1. Camaro7071
    Camaro7071 Veteran Member
    139
    Jan 13, 2003
    Upstate NY
    I picked some tire choices on tirerack and I sized up for the fronts 215/70 15's on the back I'm going with 255/70 15's do these sizes sound like they will work ok?
    Brands that they match up for are BF Goodrich TA's, Firestone firehawk Indy 500's, or Yokohama AVID s/t's...... any oppinion on brans I've only had yokohamo's out of all the brands on here
    thanks
  2. Lowend
    Lowend Administrator Staff Member Lifetime Gold Member
    13,696
    88
    Mar 25, 1999
    San Jose, CA, USA
    I will assume you are running stock 15x7" wheels
    You will be much happier with a 235/60R15 up front and a 245/60R15 out back. The car will corner, brake and accelerate much better than with the 70 series tires you previously names.
    If you want the big's n little's look than go 225/60R15 up front and 255/60R15 in back, but on the stock wheels the 255's are a tight fit on some cars
    I'd be looking at the Yokohama AVID S/T as it has a higher speed rating than the other tires out there
  3. Camaro7071
    139
    Jan 13, 2003
    Upstate NY
    Thanks! I should mention that I have US Wheel 15x8's for the front and 15x10's for the back. That should help a bit. I hope I assume they bolt up like the stock ones for backspacing and all. A lot of the problem is that I don't understand all the numbers on the tires which is the width and which is the height? I want the look with a wide tire on the back and a thinner tire on the front.
  4. BonzoHansen
    A 255/70/15 won't even fit!
    I was planning 245/60/15 all around, but finding in stock anywhere them has proven to be a challenge.
  5. Lowend
    13,696
    88
    Mar 25, 1999
    San Jose, CA, USA
    Do you know what your backspacing on the wheels is?
