TKO-500 Install/Scored on Craigslist
Discussion in 'Transmission & Driveline Topics' started by czizza, Sep 24, 2015.
  1. czizza
    czizza Veteran Member
    1,010
    53
    Jan 8, 2004
    N. Massapequa, NY, USA
    TKO-500 Install Progress and Q and A
    I am doing a how to thread on installing a TKO-500 that I recently got from Craigslist.
    The great thing is this trans has the offset shifter so I should line up where my old SuperT10 was.
    Here is the transmission, driveshaft and speedo cable I scored:
    Here is the shifter location:
  2. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    I want it!!! ;-)
  3. czizza
    1,010
    53
    Jan 8, 2004
    Guys does this look right?
    Maybe I can flip the plate and move it to the furthest point back?
  4. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    Yours is set up for a different car. Here's mine as it came from Hurst, you can see the difference.
    [​IMG][/URL][/IMG]
  5. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    I would cut the tranny for clearance and make an S or L bracket to adapt it to the proper position. Looks straight forward.
  6. czizza
    1,010
    53
    Jan 8, 2004
    That's not a bad idea. Where can I get the S or maybe a U bracket
  7. badazz81z28
    16,722
    465
    Las Vegas, NV
    That configuration must be for a different car. I don't think you can flip it. But maybe SST (formally Keisler) can help with a remedy.
  8. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    You could bend up one out of round stock or cut it out of flat stock. You could mock it up using a hanger.
  9. czizza
    1,010
    53
    Jan 8, 2004
    Yes it was a Muncie replacement. I will call them tomorrow.
  10. czizza
    1,010
    53
    Jan 8, 2004
    If sst cannot help I can weld up something.
