To those interested in fastener restoration....
Discussion in 'Original Drivetrain Topic' started by 70lt1z28, May 12, 2018.
  1. 70lt1z28
    3,319
    653
    Oct 3, 1999
    Beavercreek, Ohio, USA
  2. dave@ztech
    3,404
    703
    Mar 27, 2016
    NY
    Thanks for posting, have you used these products to restore old bolts and fasteners? How well does it work?
  3. CamarosRus
    CamarosRus Veteran Member
    8,483
    139
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    I have used the MANG PHOS solution....
    It works great and then I coat with FLUID FILM !!!!
  4. dave@ztech
    3,404
    703
    Mar 27, 2016
    NY
    What does the fluid film bring to the party Chuck? Does it make them shiny or helps resist rust?
  5. 351maverick
    351maverick Veteran Member
    3,611
    390
    Aug 11, 2010
    erie, PA
    I have 2 bottles of Palmetto Zinc Phosphate sitting here....just trying to find the time to plate some hood hinges lol
    WD40 after plating is what most guys use
  6. Smokey15
    Smokey15 Veteran Member
    3,032
    1,216
    Aug 13, 2017
    Caledonia, MI
    Gotta try this. Thank You.
  7. 70lt1z28
    3,319
    653
    Oct 3, 1999
    It works very well. Easy to do on the stove. Prep by glass beading or other thorough cleaning is important. Many parts beyond just fasteners were phosphated
  8. budro6968
    budro6968 Veteran Member
    3,151
    491
    Apr 2, 2016
    Jax Florida
    What color does it make them look like?
  9. 70lt1z28
    3,319
    653
    Oct 3, 1999
    The zinc phosphate leaves the metal with a medium grey, no shine finish. A good example is the hood hinges on a correctly restored 69-73 Camaro. Also the hood release mechanism was zinc phosphated. Manganese phosphate is darker, almost black but not quite. Also not shiny. No gloss completely flat finish. The oil, whether Fluid Film or Boeshield or WD40 is used to prevent rusting. The plating has some rust prevention, but not much. The oil soaks in and will give the part some gloss.
    Here's a YouTube on the process:
  10. dave@ztech
    3,404
    703
    Mar 27, 2016
    NY
    Nice, and easy I like it , will have to try it was well. Thanks everyone for the information!!
