To those interested in fastener restoration....
Discussion in 'Original Drivetrain Topic' started by 70lt1z28, May 12, 2018.
  1. CamarosRus
    CamarosRus Veteran Member
    8,480
    139
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    WD40 is inferior to FLUID FILM, BOESHIELD or LPS3
    Most guys are wrong !!!!!!!!!
  2. TommyRS70
    TommyRS70 Veteran Member
    1,148
    93
    Jan 31, 2004
    KY
    I use an old Coleman double burner white gas camp stove...stainless pots and trays to cook in a must, stainless dip basket with fine mesh for small parts and hardware...a thermometer, tongs or dippers.
    Bring temp up to 200 F and drop parts in solution. When fizzing stops, plating is complete. Rinse and spray with Boeshield or similar. Real easy...start with clean, rust free and pit-free hardware...I bead blast most parts.
  3. clill
    clill Veteran Member
    571
    74
    Jul 10, 2001
    Woodland, Ca. US
    But WD40 will work fine. I bet I have bolts I plated 15 years ago and sprayed them with WD40. They haven't rusted yet.
    351maverick likes this.
  4. Ed Carlson
    Ed Carlson Veteran Member
    187
    Jul 28, 2004
    amarillo TX
    get a turkey frier. hinges will fit and turn out great. ed
  5. Rickyb1968
    Rickyb1968 Veteran Member
    334
    17
    Feb 14, 2018
    Going look into this. So saving for later. Ricky
  6. Double R Restorations
    2,548
    31
    Jan 11, 2002
    I love this process, works great. I learned about it from Chuck years ago. Can anybody confirm that Palmetto Enterprises, Scott Owens is still in business.
  7. TommyRS70
    1,148
    93
    Jan 31, 2004
    KY
    Believe he is still in business. Ck out mag phos parkerizing solution on eBay.
    Double R Restorations likes this.
  8. Double R Restorations
    2,548
    31
    Jan 11, 2002
    McCune likes this.
  9. TommyRS70
    1,148
    93
    Jan 31, 2004
    KY
    I used the Palmetto Manganese chemical treatment followed up with Boeshield. Works nicely too. 0908191846a.jpg 0908191829.jpg 0908191828b.jpg 0908191813a.jpg 0908191812.jpg
    dave@ztech and 351maverick like this.
  10. TommyRS70
    1,148
    93
    Jan 31, 2004
    KY
    0907192002a.jpg 0911191804b.jpg Used zinc electroplating system on pinion nut , washer and rear sway bar drop link upper mounting nut.,.. Comes out gray, then buff to shine with soft wire wheel. 0907192003.jpg 0907192004a.jpg 0907192005c.jpg 0907192005d.jpg 0907192005b.jpg
    dave@ztech and 70lt1z28 like this.
