Trans Am Rear End Swap
Discussion in 'Transmission & Driveline Topics' started by Ferg1031, Jun 26, 2018.
  1. Zspoiler
    Zspoiler Veteran Member
    3,265
    264
    May 6, 2012
    Federal Way, Washington
    The speedometer gear may be off.
  2. big gear head
    big gear head Veteran Member
    6,187
    85
    Jul 30, 2001
    Central City, Ky.
    Nope, it has nothing to do with the drive shaft. You are going to have to change the speedometer gears in the transmission. This happens anytime you change the gear ratio in the rear end.
    mark wagner likes this.
  3. mark wagner
    mark wagner Veteran Member
    2,129
    19
    Jul 31, 1999
    Saylorsburg Pa. USA
    You need the correct speedometer gear. I don't remember which one it is, but they are plastic and color coded. They are not difficult to change either.
  4. 74BIBELOT
    74BIBELOT Veteran Member
    865
    53
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    79FD5998-16AC-4AA6-BF38-9AA974308DAB.png 03862E35-3E57-47A8-8A22-87416E9A8D60.png Speedo gears:
  5. Ferg1031
    Ferg1031 Member
    48
    May 2, 2016
    Portland, OR
    Yeah, thought I covered all my bases, feelin kinda dumb for missin this one! But, now I gotta figure out which gears I need. Anyone have experience with correcting a speedo after putting in a 3.73?
  6. MidniteZ
    MidniteZ Veteran Member Lifetime Gold Member
    624
    11
    Oct 4, 2005
    Cedar Rapids, Iowa USA
    Ferg1031 likes this.
  7. 70-camaro
    70-camaro Veteran Member
    2,388
    440
    Mar 25, 2010
    marietta ohio
  8. Ferg1031
    Ferg1031 Member
    48
    May 2, 2016
    Portland, OR
    Thanks all. I think I got it figured out.
  9. 70-camaro
    2,388
    440
    Mar 25, 2010
    marietta ohio
    Glad to see it worked out for you.
