Trans install question.
Discussion in 'Troubleshooting & Diagnosis' started by bnelson228, Apr 25, 2019.
Tags:
  1. bnelson228
    bnelson228 New Member
    19
    Mar 9, 2016
    San Marcos TX
    I’ve got a 4 spd Muncie and shifter from a 69 vette.......when I bolt this up to the bell housing in 79 second gen, the shifter looks like it sits too far to the right side of the hole in the tunnel and I can’t even run it through the shift pattern. The shifter hits the side of the tunnel. Are the shifters different from vette to Camaro?
    Im hoping that this is simply a shifter issue. I had assumed Camaro and vette shifters were the same........but I’m doubting it now. Just need a bit of advice.
  2. Dave Nelson
    Dave Nelson Veteran Member
    4,475
    2,421
    Dec 19, 2003
    Vineland N.J USA
    You will need a Hurst shifter specific for your Camaro and year.
  3. bnelson228
    19
    Mar 9, 2016
    San Marcos TX
    That’s the answer I was prepared for, Thank You.
    I’m going to assume the shift rods are the same and are moot?
  4. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
    I believe the corvette has one of it's shift arms with a curve , the camaro one is all strait down, if the rods are adjustable , they may work with the other shifter
  5. bnelson228
    19
    Mar 9, 2016
    San Marcos TX
    The rods are adjustable, so I’ll see how it goes with a different shifter. My only concern is getting the correct shifter. The 79 originally came with a b/w trans and I’m putting in a early Muncie. I guess that a shifter for a 74 should work. It’s an expensive “guess” with a $300+ dollar shifter.
  6. Jeep43
    Jeep43 Veteran Member
    1,328
    53
    Mar 30, 1999
    Connecticut
    The shifter bolts to the left side of the tail housing. If its just too far right, why not just make a spacer to move it the right amount?
    If you don't want to fab, I doubt you need a new shifter mechanism, just the adapter plate between the box and the tail housing.....
  7. Dave Nelson
    4,475
    2,421
    Dec 19, 2003
    Vineland N.J USA
    By using a spacer the shift rods will no longer be in line with the shift arms on the trans.
  8. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
    You can grab good used hurst shifter off of Ebay for less then the 300 bucks they want for a new one
  9. bnelson228
    19
    Mar 9, 2016
    San Marcos TX
    I though about a spacer, but felt that the rod alignment would be prone to binding. We’re talking a good 2” or more of offset.
