Transbrake launches are fun !!!!
Discussion in 'The BS Topic' started by muscl car, Sep 5, 2019.
  1. muscl car
    21,778
    685
    Jul 8, 2001
    High Desert of Hesperia Calif
    Got my new custom built Turbo 350 transmission installed that has a transbrake . I'm still trying to find the best rpm to launch with the 2 step but launching at 3500 rpm feels awesome
    It feels like you were rear ended by a semi truck at 60mph when you let go of the button !!! . Still not used to having to activate the transbrake to get the Camaro to go into reverse though !!!
    dave@ztech likes this.
  2. 73 Z
    944
    20
    Jun 9, 2007
    Los Angeles, Ca
    Nice! try 4/4.5k if the rear doesn't explode
    Bandit723 likes this.
  3. xten
    xten Veteran Member
    3,072
    1,837
    Sep 24, 2014
    Pittsburgh, Pa.
    Yep, they leave hard. Wait till you let that button go on a well prepped track! We need a pic of that red Camaro carrying the wheels past the 60! BTW, what diff are you running? lol
    muscl car likes this.
  4. gramps
    gramps Veteran Member
    1,030
    388
    Jul 5, 2009
    mankato, mn
    What diff “WERE” you running might be more accurate....
    muscl car and dave@ztech like this.
  5. Chevyforever
    Chevyforever Veteran Member
    664
    80
    Jan 4, 2011
    Had a trans brake, reverse shift pattern TH400 in my drag race only Camaro years ago, big block with 14x32 slicks, loads of fun !!
  6. muscl car
    21,778
    685
    Jul 8, 2001
    Running a 10 bolt with welded tubes , high strength pinion yoke , Eaton posi with 800lbs red stripe springs and aftermarket axles
    Will be upgrading to a spool !!!!
    Have you used this transbrake button from Biondo racing #HSA -01 ?????
  7. 1980RS
    1980RS Veteran Member
    3,508
    636
    Jun 17, 2006
    MN
    Transbrakes are great until....you bust an axle, break the rear end, bust the yoke, break the driveshaft, you get the idea LOL.
    Bandit723 and muscl car like this.
  8. SRGN
    SRGN Veteran Member
    681
    239
    Feb 20, 2009
    Central NJ
    Wire the trans brake to the reverse light switch. It makes everything simpler. Only bad thing is that everyone will know you are on the brake when your backup lights are on.
  9. bfmgoalie
    bfmgoalie Veteran Member
    1,994
    251
    Jun 14, 2008
    Gansevoort, New York
    I have a tranny brake with the reverse manual valve body. The tranny guy told me the torque convertor is 3800 so that's what to bring it to. Yee Haa!
  10. muscl car
    21,778
    685
    Jul 8, 2001
    Biondo racing transbrake button installed , this is their adjustable Harrington switch . Have it adjusted to the quickest release but it also can be adjusted to slow you down up to .03 Hundredths like a delay box
