Transmission for a 496 BBC
Discussion in 'Transmission & Driveline Topics' started by Brad Pankratz, Feb 23, 2019.
  1. xten
    xten Veteran Member
    2,567
    1,394
    Sep 24, 2014
    Pittsburgh, Pa.
  2. Brad Pankratz
    Brad Pankratz New Member
    9
    Feb 23, 2019
    Thanks for all the information. I definitely will go with my th400 hopefully with all this info i can get it right this time
  3. 77 cruiser
    77 cruiser Veteran Member
    530
    23
    Nov 17, 2006
    Frostbite Falls MN
  4. 1980RS
    1980RS Veteran Member
    3,031
    453
    Jun 17, 2006
    MN
    I am not sure who's building your turbo 400's but I just went through mine after 25 years of beating on it from 400hp to 700hp on NOS and the only thing that looked bad was the front pump. All the clutches were slightly worn but everything else was fine. Are you using a transbrake with your car? if so that would explain a busted trans. In all my years of putting turbo 400's together the only one that went bad was when like a dummy I put the beveled snap ring in wrong (did it twice) and had no 2nd gear. I think a redone turbo 400 from Hughes would work great or like guys say here Jakeshoe does very good work. A 4L80E is just a turbo 400 with an overdrive.
    Brad Pankratz likes this.
  5. CorkyE
    10,125
    387
    A good shop can build a TH400 that will take your horsepower and torque levels with no problem, but it will be costly. A 4L80E built to that level will be a lot more with the electronic controller, but gives that extra gear for the highway. I don't know your exact situation but "most" transmission shops don't know how to properly build a transmission to that level.
    Cardinal likes this.
  6. Brad Pankratz
    9
    Feb 23, 2019
    Thanks for the advice i will definitely use it.
  7. 1980RS
    3,031
    453
    Jun 17, 2006
    MN
    You are welcome.
  8. badazz81z28
    16,192
    378
    Las Vegas, NV
  9. C4Racer
    C4Racer Veteran Member
    608
    105
    Oct 26, 2018
    Agree. Those days are behind us.
  10. ZEN357
    ZEN357 Veteran Member
    364
    63
    Feb 12, 2018
    I would suggest a TCI Super Streetfighter TH400. I ran TCI's in the past and they always performed well for me.
