Tricks for removing sandwich motor mount brackets?
Discussion in 'Tips 'n' Tricks Topic' started by bpestilence, Jul 21, 2002.
  1. Twisted_Metal
    26,210
    577
    The one big bolt on each side can be removed to raise the engine.
  2. willem
    willem Veteran Member
    107
    Nov 6, 2017
    thanks! learning every day..
  3. jamieg285
    jamieg285 Veteran Member
    1,270
    Jul 15, 2004
    Luton, England
    A single long bolt each side is enough to separate the two halves of the mount and lift the engine out.
    If you're removing the a-arms, wait till they are out before removing the three smaller bolts, as access will be relatively easy when the arms are out of the way. I'm planning to reverse the fittings and weld the bolts into the frame from underneath when I get to that stage.
    tjmugg likes this.
  4. shanghai Kid
    shanghai Kid Member
    31
    14
    Jul 5, 2010
    I've done that many times on many projects---HaHa
  5. Ben54739
    Ben54739 New Member
    Jan 4, 2019
    Just finished up removing the sandwich mounts in my 1973 Z28. A distributor wrench did the trick for me. I probably have 1 hour into removing all 6 bolts from the crossmember. Hope this helps out. P.S. I used lots of penetrating oil prior to tackling this.
    Canadian Barton likes this.
  6. Bandit723
    Bandit723 Veteran Member
    2,705
    330
    Oct 1, 2016
    Waupaca WI
  7. smallblockchev
    smallblockchev Veteran Member
    335
    Dec 23, 2011
    st michael, mn
    Don't mean to hijack this thread but i'm replacing my stock motor mounts with new energy suspension mounts,
    Has anybody had issues with them or are they the way to go?
    My motor is a 383 stroker around 425 horse.
    Thanks for the help
    SBC
