trouble decoding VIN and trim tag on a 1975
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by ezequiel, Apr 7, 2019.
  1. ezequiel
    ezequiel New Member
    Apr 7, 2019
    Beccar, Buenos Aires, Argentina
    HAhahahaah if its that way ill drive it to usa!!
  2. Twisted_Metal
    26,430
    677
    Even if it was built for export and wasn't required to have a catalytic converter... I doubt GM would have put a floor pan from a 74 in a 75.
    If it has a 74 passenger side floor pan (no raised area for converter)... It is most likely a 74 (matches VIN) which has had 75-77 quarter panels grafted to it.
    Of course... The floor pan might not be original either.
  3. ezequiel
    ezequiel New Member
    Apr 7, 2019
    It might really i don't know how to tell!!
    how do i know if the engine is matching? j
  4. 70RamAirIII
    70RamAirIII Pontiac-aholic
    21
    Jan 10, 2005
    Calgary, Alberta
    With all due respect, I'm surprised this hasn't been mentioned before;
    It is possible seeing as this car is in South America that one of two things happened:
    1) it was rear ended and a 75-77 rear clip was installed to replace the damaged (one year only) 1974 rear clip - I can only guess how hard it would be to find rear clips in South America!
    2) it has a shady history, and was a stolen 1975-1977 model year car, with tags from a wrecked 1974 swapped on.
    If it is case #2, remove the heater box to fin the partial vin.
  5. ezequiel
    ezequiel New Member
    Apr 7, 2019
    as said before 1) its hard now to get anything here im buying parts online in usa and shipping them here.
    2) in brazil they said it was a car used in a movie and it was going to be wrecked before my friend bought it
    on monday its going to be painted and it is fully taken apart I've already removed the heater box.. ill see this week if i can take some more pictures from the passenger side floor and the other parts you are mentioning .
    by the way i don't know what a rear clip is :eek:
  6. Z28PILOT
    Z28PILOT Veteran Member Lifetime Gold Member
    2,026
    16
    Oct 8, 2009
    Emerald Isle , NC
    Im betting on the suggested theory , its a 74 car with a 75 up rear clip ( back half of the camaro body fenders and rear roof glass area ) . 74 rear clip is a one year item and is hard to find even in the USA . I would guess the correct engine block is long gone .
  7. Treyh1588
    Treyh1588 New Member
    Nov 8, 2016
    Mooresville, NC (Race city USA)
    If the floor right in front of the front seats are higher towards the middle of the car it's probably a 75. If the floor is flat from one side to the transmission hump it is probably a 74. If the original seats are in the rear the build sheet is possibly on the under side of the seat. The back window was flat in 74. It's probably long gone but you could also check the drivers door by the latch should have a blue sticker with a VIN and build date on it
