Trouble starting
Discussion in 'Engine Topic' started by Ken Rounds, Sep 10, 2019.
  1. Ken Rounds
    Ken Rounds New Member
    Aug 15, 2019
    So I recently got my 72 rs with a 327 from a ‘67 Vette. The engine appears to be stock and runs great but it doesn’t like to start without putting a little bit of fuel into the carb. It is a Quadrajet that I recently rebuilt (hoping to fix this exact issue) I’m hoping someone can help point me in the right direction to figure out this problem so I don’t just keep throwing money at the problem.
  2. 1980RS
    1980RS Veteran Member
    3,152
    507
    Jun 17, 2006
    MN
    The only time I had that trouble was with a Q-jet, if the choke does not work on them those carburetors can be a bear to start.
  3. flht99b
    flht99b Veteran Member
    190
    32
    Nov 28, 2014
    Knoxville, TN
    Welch plugs at bottom of float bowl could be leaking, common quadrajet problem. Many have used jb weld to seal them.
  4. CorkyE
    10,204
    415
    ^Would be my first thing to check^
  5. Ken Rounds
    Aug 15, 2019
    They didn’t seem to be leaking when I had it apart. Was dry when I removed the carb. And I filled the bowl with fuel while it was apart to check for leaks.
  6. biker
    biker Veteran Member
    760
    55
    Dec 7, 2014
    New Liskeard Ontario Canada
    Accelerator pump working? Idle circuit tubes plugged?
  7. Ken Rounds
    Aug 15, 2019
    The accelerator pump was replaced when I did the rebuild. The car sat for around 10 years. Where do I find the idle circuit tubes? I did clean the entire carburetor during the rebuild but this was the first one I had done so it is very possible I missed something.
