Trunk Seal
Discussion in 'Body Restoration' started by badazz81z28, Oct 18, 2019.
  1. jthomas
    1,552
    81
    Dec 5, 2007
    NorthCentral PA
    The new stuff should work great then. Metro’s finish is much better so with the new hollow core it should be the best.
  2. badazz81z28
    16,881
    496
    Las Vegas, NV
    So what's the proper way to install these? Cleaning my channel I noticed there is some seam sealer Ill need to re-apply, but do I need to adhesive the whole channel? I noticed the instructions say to put a thin bead on both surfaces and wait for it to be tacky, but we all know how cumbersome and difficult that is when your handling a very long continuous piece of rubber.
  3. GoldenOne7710
    4,824
    409
    Jun 23, 2004
    Athens, GA
    I didn't use ANY adhesive on my trunk seal. Zero issues. Once you get it seated properly, it should stay put.
  4. Twisted_Metal
    27,049
    993
    I used a thin bead of weather strip adhesive around the metal channel.
    (Test fit first and cut to proper length.)
    I glued the ends together with the same stuff.
    The ends should meet at the bottom center.
  5. 70lt1z28
    3,413
    681
    Oct 3, 1999
    Beavercreek, Ohio, USA
    giggity likes this.
