tuned port injection
Discussion in 'High Tech Retrofits' started by Erics73z, Feb 3, 2006.
  1. 1978LT
    1978LT Veteran Member
    16,280
    Feb 24, 2002
    Poquoson, VA USA
    You could break it in with a carb, then go with the TPI. You wouldn't regret that TPI! (At least to 3000 RPM)
  2. Erics73z
    Erics73z New Member
    20
    Jan 12, 2006
    are the ports from the tpi going to match up to the 400 head ports? because i have to use 400 heads because they have the steamholes.
  3. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    I don't think the ports are all that different.
    You can drill the steam holes on other heads. It's really not all that difficult.
  4. Ceth
    Ceth Veteran Member
    812
    Dec 27, 2005
    Orange County, CA
    Hey, are vortec heads smog legal? I was thinkin about running a vortec on the camaro, but I dont think there is an intake manifold for the vortecs that has an EGR valve on it.
  5. Ceth
    Ceth Veteran Member
    812
    Dec 27, 2005
    Orange County, CA
  6. Knuckle Dragger
    14,760
    1,300
    Nov 2, 2002
    Waddell AZ
    No Ceth they would not be legal. They do no allow exhaust gases to flow through the manifold and heat it up, that's part of the EFE system. Any change in engine configuration must be approved by C.A.R.B. The heads would be readily spotted by the smog tech due to the missing center bolts and the EGR tube from the exhaust, so we wouldn't be able to sneak it through either.
  7. steve80
    steve80 Veteran Member
    352
    Jun 20, 2004
    Pittsburgh, PA
    Don't forget the GMPP one for about $300. It seems to be the complete manifold. Not sure if this is what you're looking for: http://www.sdpc2000.com/catalog/737/products/8154/TBI-Vortec-SB-Chevrolet-Intake.htm
  8. Knuckle Dragger
    14,760
    1,300
    Nov 2, 2002
    Waddell AZ
  9. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    the GMPP vortec intake is over $400, and that is just the intake base..
  10. Ceth
    Ceth Veteran Member
    812
    Dec 27, 2005
    Orange County, CA
    http://www.sdpc2000.com/catalog/737/products/1112/Vortec-EGR-Carbureted-Intake-.htm
    How about if I put that intake on there, it has EGR. SOmeone told me I would have to plump the EgR myslelf though from the exhaust, because the heads dont have provisions for EGR. And would I really need a CARB number if these heads came stock in chevy cars?
