Tunnel Rams
Discussion in 'High Performance Modifications' started by Appstro, Oct 21, 2009.
  1. muscl car
    21,958
    802
    Jul 8, 2001
    High Desert of Hesperia Calif
    motor is built to specs of a motion performance phaseIII Z/30 sbc from the 70's ......... also the camaro was built to period correct specs of the 70's when a tunnel ram was the prefered intake
  2. tqueen
    tqueen Veteran Member
    238
    Sep 18, 2007
    Suffolk, Virginia
    You got to be kidding.
  3. muscl car
    21,958
    802
    Jul 8, 2001
    i said the same thing when i read his post !!!!:confused: :confused:
  4. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    "motor is built to specs of a motion performance phase III Z/30 sbc from the 70's "
    Z-30 Isky cam??
    I'd play w/ an Offy Z-28 intake instead of a tunnel ram. I'd use the 3x2 top.
    Or create a modern version of a 4x2 Man-A-Fre Port Induction intake by setting the 4 barrels in line w/ the ports under each of them and making a mounting plate for each pair so that I could run one long butterfly shaft for both 2 barrels on each side!
    I'd also use the big Rochester 2GC's vs the little 2G's to feed her.
    Weber carb's would be great, but PRICEY, imho...
    pdq67
  5. tubbedz
    tubbedz Veteran Member
    118
    Apr 9, 2008
    United States
  6. muscl car
    21,958
    802
    Jul 8, 2001
    the Z/30 isky was only 250 @ .050 and 480 lift !!!
    1rst design off-road cam GM#140 mechanical flat tappet 257/269 @ .050 493-512 lift 112 LSA 4200-7200rpm
    before the edelbrock TR1-X is was running a edelbrock TM-1 tarantula single 4bbl intake
  7. muscl car
    21,958
    802
    Jul 8, 2001
    quoted from the article....
  8. anesthes
    anesthes Veteran Member Lifetime Gold Member
    868
    Jun 17, 2009
    Salem, NH
    No.
    Every street car I've seen with a tunnel ram was kind of slow.
    While, perhaps a large cube, high revving drag car might do well, how many of those are on the street?
    Again, it's not worth it to me to have something sticking out of the hood on a small block when the same power (and more) can be achieved without the visual block. If that point is misunderstood, well, I can't help.
    -- Joe
  9. Appstro
    Appstro Veteran Member
    242
    May 16, 2009
    San Diego, CA
    Sounds like a tunnel ram is great for the strip in the 3500-8000 rpm range. Not for street use at all ( but sure looks bitchin'). I love the way they look. Definitely need to learn how to tune them though.
    I read the rest of the Car Craft article...
    "As far as the Indy manifold is concerned, we were surprised to find a four-barrel intake that came as close to the output of the tunnel-ram as this one did. Indy certainly did its homework when it produced this clean-slate design. For sheer user-friendliness, look no further than the Indy manifold. We bolted this induction on and laid down well over 500 hp at the wheels. It doesn't get any simpler. Hood clearance with anything more than a 1-inch filter element may be a problem, but the packaging is much more user-friendly than it was with the ram. Indy Cylinder Heads has produced a winner. Not only did it keep the tunnel-ram in sight, it proved much less complex to set up. With the Indy intake, you don't need an expert tuner to get you dialed in. Just bolt it on, make big power and go. For many, that's good enough."
    Hmm. This is good stuff :)
  10. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    Would I pull the extensively tweaked handmade sheet metal tunnel ram off of a Pro Stock engine and bolt on an as cast or even "Max-flowed" single 4bbl singleplane intake? NO.
    Does your average Pro Stock see much action below 6,000 RPM?
    Nope.
    Not many of us have 10,000 rpm capable 500 cu in motors with ports the size of a linebacker's arm either.
    A 32 coupe, maybe a 57 Chevy etc going for the "cool factor" with a tiny port, tiny plenum TR with tiny carbs to go with those lawnmower motor sized air filters maybe OK.
    Just don't bolt a TR on a stock 72 Chevy PU and try to stomp on it from idle at the Sonic,,,, unless you like big fireball backfires, cranking it a half minute to restart while the whole place is laughing.
