Tunnel Rams
Discussion in 'High Performance Modifications' started by Appstro, Oct 21, 2009.
  1. machinestheman
    machinestheman Member
    38
    Jul 8, 2010
    savannah, GA
    79 z28
    well i just got this car and i actually know very little about its actually build other than i have great confidence that the guy knew what he was doing when he built it it was a running 1/4 mile engine that was pulled for a big block it is a 355 with aftermarket aluminum heads 1.6 roller rockers tunnel ram and dual holley 650 carbs it has not yet been fired on this setup due to i still need to buy a distributor which i found out that an hei just will not do lol and i will need to get a new fuel pump and regulator and mostlikely ditch the current fuel rail heres a pic of my setup tell me what you think
  2. machinestheman
    38
    Jul 8, 2010
    savannah, GA
    and oh yes i plan on driving this on the streets i am in ga so the cold weather shouldnt be a problem also what stall should i look at getting with a setup like this for a street/strip car
  3. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Why do you assume the HEI won't fire??
    If it's got very little load, it will fire fine.
    Do you know it's got big compression, or a street set up??
    Big difference in spark requirements for an all show engine, and a all go set up.
    Also, I'm not a fan of those fuel lines or header wrap on the street.
    Good luck.
  4. Appstro
    Appstro Veteran Member
    242
    May 16, 2009
    San Diego, CA
    HEI wont fit will it?
  5. machinestheman
    38
    Jul 8, 2010
    savannah, GA
    nope but i sure did try im looking for a msd 85551 or equivelant i already have a msd gal ignition module and a msd blaster 2 coil so figure i would just do msd for the distributor magnetic pickup and mechanical advance
    and the engine might look like it was built for show but i assure you it wasnt
  6. machinestheman
    38
    Jul 8, 2010
    savannah, GA
    the engine is some where in the 11-1 to 11.9-1 and it really sucked hand rolling it to tdc with the plugs in
  7. mrdragster1970
    7,822
    507
    Apr 12, 2007
    Good call, forgot how big they are.
    I was asking if it's show or go, I did not assume either way.
    Even though with such tiny carbs, I probably did assume low compression, mild power.
    I've seen some decent power engines with a HEI is the point I was making,
    but they had plenty of room.
    So what are the specs, how streetable is it, how much power.
    Hard to pick a stall from a pretty picture??
  8. machinestheman
    38
    Jul 8, 2010
    savannah, GA
    unfortunatly im sure the hei would fire if i could actually get it into the block its too big i need a much smaller distributor but i already have a msd 6al and a blaster 2 coil so i figured i will go with the msd 85551 and it dosent have vacuum advance and i assure you that this engine wasnt built for show before the tunnel ram and new cam it put down 508 to the wheels in a 67 camaro the rest of the drive train unknown but i also know he was also shooting a 100 shot of nos so i know the compression isnt more than 12.5-1 and is more like 11.5-1
  9. machinestheman
    38
    Jul 8, 2010
    savannah, GA
    what i know about the motor is that the cam was picked just for that tunnel ram intake and the two 650 holleys so big lift definatly it also has a set of 1.6 roller rockers aluminum heads and i cant even tell you what brand they are i havent even looked but i believe they have 207 valves tho and for now its the stock rearend whick i aswell dont know much about other than it has a chrome cover lol and the trans is a th350 with a shift kit hope that helped you out a bit
  10. bracketracer-78
    bracketracer-78 Veteran Member
    730
    61
    Sep 5, 2003
    Stevens, PA USA
    I had this in my daily driver for awile.
    This was my daily driver during the summer months.
