Turbo 350 leaking when not running
Discussion in 'Troubleshooting & Diagnosis' started by rocket dawg, Sep 13, 2019.
  1. rocket dawg
    rocket dawg Veteran Member
    335
    29
    May 5, 2015
    Grand Rapids Mi
    Seems to be on the passenger side of the trans, probably the dipstick or the cooling lines. Does not leak when hot and running. Sent the car into a trans shop to fix all the leaks and mechanic couldnt get at the large round seal ( accumulator? ) on that same side because the header/exhaust was in the way. Seems to me that part is high enough that it wouldn't leak while not running. I replaced the dipstick and seal with something similar to this one seal wise (cant find the exact one I bought.) The leaking is getting worse. I've had daily driver 350's that never leaked a drop, probably 5 different ones over the years. Gonna drop the trans this off season and replace whatever needs to be replaced. I need a dipstick that dont leak. I stored the car for years without it leaking, now it leaks overnight and it's more than an occasional drip, it leaves a puddle. thanks seal is listed below from summit
    https://www.summitracing.com/parts/ado-1259475
  2. Twisted_Metal
    27,157
    1,046
    Fluid flows back from the converter and the level is higher when it's sitting.
    TH350 transmissions used a couple of different dipstick tubes and seals over the years.
    One had an O-ring which fit into a groove in the dipstick tube and seated in a grove in the transmission case.
    Others used the top-hat seal. (Which is what you linked.)
    The top hat design won't seal properly in a transmission designed for an O-ring seal.
    You'll need to check the tube and case for that groove and use an O-ring seal if that's what you have.
    Even then... You may need to use some hi-temp RTV to get it to properly seal.
  3. rocket dawg
    335
    29
    May 5, 2015
    Grand Rapids Mi
    Yes, it originally had an O-ring tube on it. Interesting. Anyone spend the big dollars and get a Lokar flex tube? It needs the pan dropped because a fitting goes inside. If I drop header or the exhaust, is it difficult to replace the accumulator O-ring? Trans fluid is thin and the whole side of the trans is wet and really hard to pin point the leak. thanks for the info!
  4. cadillac_al
    cadillac_al Veteran Member
    847
    89
    Apr 22, 2015
    Maine
    I replaced an O-ring dipstick tube with the hat style and solved my leak. I don't think your seal should be leaking.
  5. larrylarry
    larrylarry Veteran Member
    1,553
    72
    Dec 22, 2011
    San Antonio Tx
    Accumulator o ring is easy to change. When you remove it you have a flood of trans fluid coming out. The trans pan bolts are only around 10 ft lbs of torque, something to remember.
