Turbocharged 70 RS project
Discussion in 'Project Progress' started by Turbo70Camaro, Jun 12, 2010.
  1. onebad71
    onebad71 Veteran Member
    412
    May 15, 2010
    georgia
    thats one hell of a turbo
  2. Rajin
    Rajin Veteran Member
    122
    Jun 28, 2009
    Kelowna, BC
    What the hell is that turbo off of? It's massive!
  3. delete-Z
    delete-Z Veteran Member
    173
    Nov 27, 2009
    Crawfordsville,Indiana
    WOW! that is going to be awsome!
  4. Turbo70Camaro
    2,146
    117
    Jan 7, 2005
    so cal
    Finally got my fuel rails so now I need to cut, drill and assemble. Intercooler brackets will be done end of week so more pics to come with intercooler mounted and mocking of cold side :D
  5. 78camarodude
    78camarodude Veteran Member
    133
    Jun 20, 2010
    bennett,colorado
    Injected turbo big block holy crap that things going to move
  6. JPM
    JPM New Member
    11
    Jul 18, 2009
    Southeast Texas
    camaro
    Rustorbust, I'm doing the same as well. I have a 468 8/1 compression big block with all forged internals built and running on a stand. I have all drivetrain components ready with the BW S480 turbo sitting and waiting. The body is what I'm working on now. I have quarters and valences to hang and put the chassis together before I can put the motor in. I am going blowthru as well and using a Brent Davis modified carb to do so. It's already been tested on a 1400 hp car and it works flawlessly. The powervalves are turned on by an MSD rpm switch and open when I want em to. I think it will make enough power to completely destroy the bottom end if I turn it up. This is one build I'm gonna follow for sure. Good work.
  7. rustorbust
    rustorbust Veteran Member
    242
    10
    Dec 14, 2009
    San Diego
    Very cool, do you have any pictures of the car?
  8. JPM
    JPM New Member
    11
    Jul 18, 2009
    Southeast Texas
    camaro
    I do, but believe it or not, I've NEVER posted pics on a forum. I will have to learn and then get some practice. I will try though.
  9. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    Sounds good, you should start a new build thread for your car in the project section I'm sure there is prob quite a few people that like to check it out. The carb that you have is it the one that the power valves are activated by the small air pump? And the turbo, is it the 1.32 exhaust housing?
  10. JPM
    JPM New Member
    11
    Jul 18, 2009
    Southeast Texas
    camaro
    Yes and Yes.
