Turbocharged 70 RS project
Discussion in 'Project Progress' started by Turbo70Camaro, Jun 12, 2010.
  1. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    I have a new roll coming next week I'll weigh it for you.
  2. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    Came in early :)
    60” x 36” 6.5 pounds.
  3. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    Finally got the turbo upper support bracket figured out...
    And mock up template for the electronics mounting panel...
  4. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    Walla panel ready for install 10ga aluminum.
  5. rustorbust
    rustorbust Veteran Member
    242
    10
    Dec 14, 2009
    San Diego
    Looking fancy. I need to do something like that in my car. I originally mounted all the Holley stuff to a panel on the roll cage in the passenger side and have grown to not like it. I like what you did.
  6. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    i can give you the template it fits perfect you just need to bolt the back side to the firewall.
  7. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    I appreciate that but I doubt it would fit now. All the intercooler pipes run right up through that area.
  8. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    you need to regularly post up pictures brother i'm losing track of what you got going on with the car.....
  9. rustorbust
    242
    10
    Dec 14, 2009
    San Diego
    Right on, Ill try to add some more info today. I have done quite a bit over the last couple months. I'm waiting on some back ordered Holley parts then it will be running.
    Turbo70Camaro likes this.
  10. Turbo70Camaro
    2,141
    115
    Jan 7, 2005
    so cal
    Starting to mount the electronics on the panel, more to come. .....
