Turn signals wont work
Discussion in 'Troubleshooting & Diagnosis' started by Terrys75LT, May 12, 2019.
  1. Terrys75LT
    Terrys75LT New Member
    May 12, 2019
    I just got a 75 LT and someone cannibalized the turn signal connector on the main harness side. It was a project when I got it and not running. It's running great but now I'm down to the under dash, guages etc. I'm thinking grounding issues. Does anyone know the locations?
  2. Gary S
    22,099
    648
    The grounds should be near the lights themselves. However, if the wiring is chopped up, it likely can't work anymore.
  3. Terrys75LT
    May 12, 2019
    There is one wire missing off the original harness (black one). There are solderless connectors on the rest of them (9 total). That’s why I asked about the location of the ground under the dash.
  4. Gary S
    22,099
    648
  5. Terrys75LT
    May 12, 2019
    Yeah I’ve been working with these and actually the parking and brake lights work. The hazard and signals are not. Wasn’t sure if a ground somewhere in that circuit was the cause. Car has been dirty for quite a while and has been worked on by someone without much electrical knowledge.
  6. Terrys75LT
    May 12, 2019
  7. azkeebler
    azkeebler Veteran Member
    584
    Dec 14, 2011
    Manteca, ca.
    What may have happened, it looks as maybe the prior owner installed a later year column that had a different turn signal harness and they just cut and connected. Taillights on the 77 and earlier obviously are wired differently than the 78 and up, i believe you need to move the white wire one terminal over in the connector to supply power of turn and hazard to your lights as it may currently be wired for 78- up segregated turn and brake light system.
  8. 71flh
    71flh Veteran Member
    979
    23
    Jun 1, 2010
    DFW
    The brake lights, hazards and signals all use the same filament in the bulbs. Thus there is no ground issue and the filaments aren't burned out.
  9. Terrys75LT
    May 12, 2019
    After further testing that's exactly what happened. Thanks
