Twin Turbo LS2
Discussion in 'High Tech Retrofits' started by mwhizard, Mar 2, 2011.
  1. luv2drift
    luv2drift Member
    82
    Feb 16, 2010
    Centralpoint, OR
    most people use cast manifolds because you don't have to worry about cracking. i have had friends who used turbo headers and it gets so hot that the pipes will just crack. a cast manifold will never have that problem.
  2. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    looks great:cool: keep the progress pix comming....
  3. mwhizard
    mwhizard Veteran Member
    210
    Aug 28, 2008
    Vancouver, B.C.,Canada
    To answer some questions, I am a licensed motorcycle mechanic and an apprentice elevator constructor. My dad brought home an arc welder when I was 11 years old and I have been building things ever since. I will for sure be running this car at Rivers edge in the solo sprint class. The reason for the manifolds is indeed strength. Thats also why I am using the schedule 10 stainless steel on all the pressure side hot side plumbing. It is nice and sturdy, holds up to heat and expansion well, and won't tend to leak like headers can. I am always ready to accept free beer.... here's some more pics..
    Car last summer at track
    I was short shipped 1 intercooler so here's one of them, ready for fab work.
    Here's the 2 pipes that go to the waste gates. Again had to bore out schedule 40 to get my schedule 10. These are 1.5"
  4. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Excellent! See you there!
  5. mwhizard
    210
    Aug 28, 2008
    Mounted the wastegates today and built 1 downpipe. After the spiggot was welded onto the main pipe, I just ran a holesaw through the middle, then cleaned it up with a carbide bit die grinder.
  6. djorgensen3
    djorgensen3 Veteran Member
    487
    51
    Oct 15, 2009
    Peoria, Az
    Are those VB&P control arms with the transverse leaf on the front?
  7. mwhizard
    210
    Aug 28, 2008
    No transverse leaf. They came with the car. I do plan on replaceing them sometime.
  8. mwhizard
    210
    Aug 28, 2008
    Completed the down pipes today. Just the dump pipes left to go on the hot side then it's on to the intercooler pipes.
  9. jakemuns
    jakemuns New Member
    13
    Sep 6, 2010
    St. Cloud, MN
    This is one hell of a build. Great work!
  10. luv2drift
    luv2drift Member
    82
    Feb 16, 2010
    Centralpoint, OR
    nice mounting point for the waste gates. very clever using a hole saw after it's welded to cut a perfect hole. should make the flow a lot better than if you had tried to cut it in advance because the hole will fallow the id of the pipe better.
