Type II Power Steering Pump
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Rayden2009, Aug 11, 2019.
  1. Rayden2009
    Rayden2009 Veteran Member Gold Member
    111
    14
    May 12, 2016
    Calgary AB
    I just replaced my saginaw tear drop power steering pump with a Type II pump from Turn One. Wow, what a difference. My old pump was from Lee Power steering, and it struggled to turn the wheels at a stop with the engine at idle. I have a Lee box, 245's in the front and just added a Lee inline filter. I would not have done this except my old power steering pump had a relief issue and was leaking (only 2 summers of driving...). I bit the bullet and called Turn One. I am planing on adding Hydroboost and a cooler, so they increased the pressure the pump could produce. Since the install, i've only driven it once, but i'm very impressed. Noticeable improvement over the teardrop pump, and mine was from Lee, not original. You can get a type II box a hell of a lot cheaper then the route I went, but only the best for my car....
    Here are some pics. I learned a bit from this experience, and when I add the cooler and Hydroboost I think I can clean the hoses up a bit. I had to use 10 washers per bolt to move the bracket forward to match the long water pump pulleys. Most manufactures only make brackets for short water pumps, which makes no sense to me.
    Here are some pics:
    Redneck bracket extension from short to long water pump:
    I hope that Lee inline filter is worth the trouble. I like that I have increased my fluid capacity, thus diluting contaminants. I hear they are overkill but what the heck. The cooler will eventually go in front of the rad, but I will need to take the nose off the car which i'm not ready to do yet. I filled it up with Amsoil power steering fluid. My neighbour happens to be an Amsoil dealer, so I support him, plus its up there with the best fluids.
    Type II PS pump is the way to go if you have the funds. Half the weight, half the HP consumption, less heat generated and more consistent feel from stop to full speed, plus it looks sleeker. I Highly recommend it.
    John Wright likes this.
  2. dave@ztech
    3,399
    703
    Mar 27, 2016
    NY
    Nice!! I have been looking at these pumps as well, having trouble getting the answers for them regarding what will fit my setup, I am switching to the old serpentine system for 88-95 GM vehicles , so, had to find AC delete, easy, reverse rotation water pump, easy, reverse clutch and fan, easy, pump??? not so much, none want to commit , that it will fit, I have to wonder about the increase in pressure, I thought?? that higher then needed pressure would screw up the steering gear, and I have a 670? gear from DSE that I want to have it last a minute, advantage, is it is already set up with the metric fittings, so the lines will be easier, HAA HA
  3. Rayden2009
    111
    14
    May 12, 2016
    Calgary AB
    I asked Turn One if the increase in pressure will hurt anything since I don't currently have hydroboost. They told me not to worry, the pump only puts out what is required so it wont put out 1800 psi unless I am steering and braking with hydroboost at the same time. Hope they are correct. I know the new hydroboost plumbing will have the hydroboost right after the pump, followed by the steering box in series so I would assume the steering box will never see the higher pressures.
    Call up Turn One. Maybe they can help you. They seem to know their stuff
    dave@ztech likes this.
  4. dave@ztech
    3,399
    703
    Mar 27, 2016
    NY
    I will, and what Hydro boost, the CCP one, looks like a nice unit, and seems like a good price.
  5. camaro71/holland
    1,219
    76
    Aug 27, 2003
    The Netherlands
    What fitting did you use on plastic return tab from the reservoir?
  6. Rayden2009
    111
    14
    May 12, 2016
    Calgary AB
  7. Rayden2009
    111
    14
    May 12, 2016
    Calgary AB
    I ordered the pump with a AN-6 return fitting right from Turn One
  8. dave@ztech
    3,399
    703
    Mar 27, 2016
    NY
  9. UMI Tech
    UMI Tech Member NazstyZ28 Sponsor
    51
    28
    Jan 10, 2017
    Central PA
    We use the Turn One pump in our car with their 8:1 gear for autocross. Feels awesome and works trouble free.
  10. Rayden2009
    111
    14
    May 12, 2016
    Calgary AB
    Thought I would post an update after driving the car a bit. Still really happy with the pump. Seems to have smoother and more consistent feedback at all speeds then before. It does require a little bit more effort, which I like. I checked it lock to lock at idle, and it did groan a bit, but the engine rpm did not drop at all. My old pumps groaned too but seemed to put a lot more load on an idling engine, and rpm would flutter.
