UK Camaro SS 1972 Restoration
Discussion in 'Project Progress' started by StephenShoubridge, Nov 1, 2018.
  1. StephenShoubridge
    StephenShoubridge Member
    51
    42
    Oct 20, 2018
    UK
    Now off the rotisserie
    Ride Tech rear frame fitted
    IMG_5189.jpg IMG_5188.jpg IMG_5186.jpg IMG_5185.jpg IMG_5184.jpg IMG_5183.jpg
  2. Zulu28
    Zulu28 Veteran Member
    287
    22
    Dec 19, 2013
    Vancouver, BC
    Top shelf build, I'm running the same suspension and not sure about how to build the tailpipes, did you have to run the tail pipes under the axle?
  3. StephenShoubridge
    51
    42
    Oct 20, 2018
    UK
    I've run the exhaust under the axle
    Not the best pictures but hopefully will help.
    IMG_4144.jpg IMG_4145.jpg IMG_4146.jpg IMG_4140.jpg IMG_4141.jpg IMG_4142.jpg
  4. Zulu28
    287
    22
    Dec 19, 2013
    Vancouver, BC
    Thanks for that! with 3" pipe there's not alot of choice for exhaust routing especially if you use the high mount rear sway bar.
  5. StephenShoubridge
    51
    42
    Oct 20, 2018
    UK
    Within the next 10 days, hopefully finished the paint process.
    When assembling the front end ( as not to scratch paint with luck}
    Is this the correct assembly order?
    1. Doors - (have previously drilled small alignment holes)
    2. Radiator Panel
    3. Inner Fenders
    4. Outer Fenders
    5. Hood
    6. Then adjust for final alignment before tightening
    Much appreciated
  6. thesalboy
    thesalboy Veteran Member
    352
    122
    Mar 25, 2017
    Los Angeles, CA
    I would leave the inner fenders out and install them only after fenders and hood are aligned.
    bodymanbill likes this.
  7. StephenShoubridge
    51
    42
    Oct 20, 2018
    UK
    The car has now been painted
    Front subframe also fitted
    Cutting & polishing at the moment
    Well pleased with the end result
    IMG_5278.jpg IMG_5292.jpg IMG_5291.jpg IMG_5289.jpg IMG_5287.jpg IMG_5284.jpg IMG_5283.jpg IMG_5282.jpg IMG_5281.jpg IMG_5280.jpg IMG_5279.jpg
    BillyDean7173 and roadrace2 like this.
  8. BillyDean7173
    BillyDean7173 Veteran Member
    1,636
    332
    May 21, 2014
    Hutto, TX
    Awesome color and love that hood. Bad to the bone.
  9. SPG
    SPG Bumblebee Builder
    369
    62
    Sep 1, 2018
    Sacramento
    That hood is pretty kickas, I haven't really seen that style used, mainly see cowls
  10. Bills69
    Bills69 Veteran Member
    115
    May 28, 2018
    great color
