UMI Performance Cruise In & Autocross- August 11th-12th, Philipsburg- PA
Discussion in 'UMI Performance' started by UMI Performance, Jan 30, 2017.
  1. Vsolo
    Vsolo Veteran Member Lifetime Gold Member
    821
    10
    Sep 20, 2009
    So Central PA
    Scott, It was great talking to you at the AutoCross.
    It was a blast tearing up the track too
    I have not forgotten, I've been busy.
    I'm supposed to remind you to send me the info about the rim and tires :) 39610625_2193754294189386_2025312439976853504_o.jpg UMI-huge1.jpg
  2. BonzoHansen
    I better look it up this week!
  3. Schubitzky
    Schubitzky Veteran Member
    319
    Mar 10, 2003
    Maryland
    I'd like to get that info too please!
  4. BonzoHansen
    As per my receipt: Forgestar Super Deep F14 18x9.5", +11mm offset
    I had to have Forgestar drill the center bore out to accommodate the front hubs. I did all 4 since they are all the same, I'd like to be able to rotate - just a side advantage to being square. But now no center caps. If you used spindles that utilize C5-6-7 bearing backs that would not be an issue.
    I run a .125" baer spacer on one side - the rear is off by 1/4". I just had a little rubbing on my 3" tailpipe on the LH side.
    I did have some rubbing issues with the hotchkis front sway bar on full lock. I ended up adding some 1/4" gr8 bolts to the steering stop brackets on the LCAs. I may eventfully get the PTFB front sway bar that offers more clearance.
    Running 275/35/18 Firestone Indy 500s all around. A summer tire, but not a race tire. I need to learn how to drive before i dump rival money. Still way better than the now retired Dunlop Qualifiers.
    Cut about 8 pounds per wheel assembly compared to stock 5 spokes & 245/60/15s
  5. Vsolo
    821
    10
    Sep 20, 2009
    So Central PA
    Thanks, Ignore my PM's :)
