UMI Releases 2nd-Gen F-Body Stage 2 and 3 Handling Kits!
Discussion in 'UMI Performance' started by UMI Performance, May 22, 2019.
  1. UMI Performance
    UMI Performance Member NazstyZ28 Sponsor
    73
    23
    Apr 11, 2015
    Philipsburg, PA
    The NEW Stage 2 F-Body kit, also known as our Power Tour Package, features everything you need for your pride and joy to reliably travel thousands of miles at a time in corner carving comfort.
    Caster corrected, tall ball joint a-arms tune up the geometry to plant that tire during cornering as well as offering some excellent straight line stability.
    High rebound monotube shocks and heavy duty sway bars keep the sway to a minimum and provide great ride comfort.
    Out back, Made In USA lowering leafs combined with carefully calibrated high rebound monotube shocks steady the 2nd Gen platform and provide a pleasant driving experience.
    UMI-built shackles house poly bushings and pads so dry rotted rubber can be a thing of the past. Your 2nd Gen will feel refreshed and capable after receiving this Stage 2 package, that's for sure.
    If you're looking for more we have a Stage 3 kit and both kits can be upgraded to Viking Performance dual adjustable shocks to really dial in that ride.
    UMI Stage 2 and 3 Handling Kits
  2. camarochevy1970
    camarochevy1970 Veteran Member
    7,719
    40
    Jan 23, 2003
    Pittsburgh, PA
    that's a good looking kit. Now if I only had money :D
    75Maro likes this.
