UMI's Newest Test Vehicle- 1971 Camaro, Pro-touring Project
Discussion in 'Project Progress' started by UMI Performance, Jan 12, 2017.
  1. UMI Tech
    UMI Tech Member NastyZ28 Sponsor
    59
    33
    Jan 10, 2017
    Central PA
    Hi Dave.
    We have custom inner fenders designed and built by our in-house fabricator. The 315 and 18x11 would of course have no chance with stock inner fenders.
  2. BonzoHansen
    19,500
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    What spindles are being used?
  3. UMI Tech
    59
    33
    Jan 10, 2017
    Central PA
    Crazy thing is, we are using factory spindles. The car works incredible with the #cornermax system on it.
    BonzoHansen likes this.
  4. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    I need to look into this, an 18x11 on the stock spindle and full range of motion(steering angles).
  5. UMI Tech
    59
    33
    Jan 10, 2017
    Central PA
    The tires rub at full lock. They never rub on the street or road race track. Of course it's key that the inner fenders are modified.
    John Wright likes this.
  6. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    I need to modify my inner fender liners as it is, my turbo takes up some of that real estate.
  7. UMI Tech
    59
    33
    Jan 10, 2017
    Central PA
    The UMI '71 Camaro and lead mechanic (and really good driver) Roger Irvine with crew chief Nate Peterman (and really good UMI engineer) won the Northeast Musclecar Challenge this past weekend. This car features our CornerMax front suspension and steel leafs out back with a prototype adjustable sway bar and some good shocks. Power is NA LS3.
  8. UMI Tech
    59
    33
    Jan 10, 2017
    Central PA
    UMI '71 Camaro underside shot.
    mrfleet12, roadrace2 and John Wright like this.
  9. czizza
    czizza Veteran Member
    1,042
    76
    Jan 8, 2004
    N. Massapequa, NY, USA
    Those inner finders and chassis parts look awesome ... are you also making the lower adjustable spoiler?
    Also the website is missing all these glorious parts.
  10. dcozzi
    dcozzi Veteran Member
    3,153
    448
    May 1, 2002
    Phoenix, AZ
    Ramey, I wish you were not on the other side of the nation. I would love to borrow those front wheels to help measure my required inner fender modifications.
    Even with a 10" tread width tire, I am finding it within 1mm of the painted sheet metal. I am thinking of bringing the whole inner inside the fender itself so I can bend it back towards the rear of the opening.
    18X11 fronts with a 315/30/18 may not be possible on my particular car without tweaking the painted metal a lot.
    Do you plan to go to a Watts setup eventually or does the leaf setup work too well to consider it?
