UMI's Newest Test Vehicle- 1971 Camaro, Pro-touring Project
Discussion in 'Project Progress' started by UMI Performance, Jan 12, 2017.
  1. 70ZED
    70ZED Veteran Member Gold Member
    364
    34
    Jun 21, 2010
    Calgary, Alberta Canada
    I like your approach for sure !!
  2. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
    Pretty sure that is a composite spring.
  3. John Wright
    14,714
    216
    Aug 9, 2002
    Rustburg, Va
  4. mid77z28
    mid77z28 Veteran Member
    201
    Nov 15, 2002
    wallingford,ct.
    Are you using the tall ball joints on that system?
  5. UMI Performance
    UMI Performance Member NastyZ28 Sponsor
    74
    46
    Apr 11, 2015
    Philipsburg, PA
    Hey everyone,
    Hopefully I can answer all your questions here. Yes, that rear brace is for a Watts Link. Those are composite leafs outfitted with our Roto-Joints and yes they have been relocated slightly.
    We have been chipping away at the car among other projects. Right now it's a lot of the boring/tedious things like plumbing and wiring. Crucial but not very exciting to show! However we did get the front Wilwood brakes mounted up. We also wanted to see how the new Forgeline wheels looked, so we mounted up one of those with a 315 series BFG Rival tire. A lot of tire but should help us maintain traction.
    1971 Camaro Currie Wilwood UMI Performance 01.JPG 1971 Camaro Currie Wilwood UMI Performance 05.JPG 1971 Camaro Currie Wilwood UMI Performance 07.JPG 1971 Camaro Currie Wilwood UMI Performance 08.JPG
  6. UMI Performance
    74
    46
    Apr 11, 2015
    Philipsburg, PA
    Few more pics of the wheel/tire combo. 1971 Camaro Currie Wilwood UMI Performance 02.JPG 1971 Camaro Currie Wilwood UMI Performance 03.JPG 1971 Camaro Currie Wilwood UMI Performance 06.JPG
  7. GDSmith
    GDSmith Veteran Member
    149
    26
    Aug 4, 2012
    Glen Ellyn, IL
    Whoa, this read has been very informative, thank-you! 6-7 years ago I did my LS conversion along with a bunch of other work, there wasn’t a fraction of the components available as currently. One item I have been delaying is the roll cage, haven’t seen an aftermarket that appears to follow the body as your appears, will the cage components be available for purchase?
    Thanks and keep posting
  8. Lowend
    15,141
    544
    Mar 25, 1999
    San Jose, CA, USA
    Really liking those firewall braces
  9. djkaplan
    djkaplan Veteran Member
    162
    Mar 27, 2016
    Victoria, bc
    [QUOTE="UMI Performance, post: 3534751, member: We prepped a few plates for the cage to sit on as well.
    [​IMG][/QUOTE]
    Those are the best roll bar floor plates I've ever seen!!
    You guys should sell those things.
    I can guarantee I'd be buying!
  10. Dichard
    Dichard Veteran Member
    164
    121
    Jul 5, 2018
    Mesa, Arizona
    #1. What kind of life do you look at getting out of the heim rod ends on the upper control arms?? They look like they will last, but I always have my doubts about heim rod ends on the street.
    #2. Also a question on the roll cage mounts, what are the thickness of the plate and do they bolt in or weld in?? Curious on these because the leaf spring perch is right below that location.
    hubedobeedo likes this.
