UMI's Newest Test Vehicle- 1971 Camaro, Pro-touring Project
Discussion in 'Project Progress' started by UMI Performance, Jan 12, 2017.
  1. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,025
    149
    Dec 19, 2008
    One hell of a build!!
  2. camaro71/holland
    1,263
    92
    Aug 27, 2003
    The Netherlands
    Bitch'n :bowtie:
  3. QUAKE_WARS
    2,025
    149
    Dec 19, 2008
  4. Lowend
    15,141
    543
    Mar 25, 1999
    San Jose, CA, USA
    Sam Strano is driving it at the CAM challenge this weekend if I'm not mistaken
    BonzoHansen likes this.
  5. UMI Tech
    UMI Tech Member NastyZ28 Sponsor
    60
    33
    Jan 10, 2017
    Central PA
    You are correct Lowend. We had Sam and our car chief Roger (Sam's protege' at the moment) at CAM Challenge. We unfortunately had a clutch problem and couldn't make the start. Turns out it was just bad timing as we had given a hundred laps of rides two weeks earlier...
    The car has been working well, as it went 165 at Optima Daytona on the highbanks and won Drive USCA auto-x a week prior.
    The latest round of upgrades is to the body, with Anvil Auto carbon and Trackspec vent pieces. We are also working on the graphics to make the hood stripes match. We ran out of time before it pulled out last week.
    We are currently on UMI steel leafs (same leafs that come in our street packages) as we found the Watts Link and composite leafs were in a little bit of conflict with each other. The steel leafs and a light sway bar are proving pretty excellent.
  6. Dichard
    Dichard Veteran Member
    164
    121
    Jul 5, 2018
    Mesa, Arizona
    Why hasn’t anyone fromUMI posted a reply to my questions, I asked these about 2 weeks ago. Come on guys what’s up here
  7. UMI Tech
    60
    33
    Jan 10, 2017
    Central PA
    We have rod end arms on a few hundred cars with no complaints. Rod ends down low on lower a-arms or trailing arms tend to get noisy. Since upper arms are just a pivot, and not as "load bearing" they seem fine.
    The lower plate is 1/8" cut on our laser. The holes are in there for plug welds. This was an in-house thing and isn't intended for production.
    ramey
  8. Dichard
    164
    121
    Jul 5, 2018
    Mesa, Arizona
    I appreciate the reply Ramey,
    I understand about the lower, I was curious about the uppers, working in the aviation industry I see many heim ends and how long they last on aircraft, but my knowledge base is somewhat limited on the application in the automotive industry. Again, I appreciate the response. I like what UMI is doing. Keep up the great work.
  9. UMI Tech
    60
    33
    Jan 10, 2017
    Central PA
    I think in a long term test, the non-adjustable Delrin uppers would last longer and stay quieter longer. The good thing is, we have Chevelle uppers going on six years with "discriminating" customers who don't need rod ends replaced.
    We also run this style upper on our A, G and this F-body and the rod ends don't exhibit wear after seasons of abuse. Our LeMans just turned 1800 (brutal) track miles on the original set.
    hubedobeedo likes this.
  10. dcozzi
    dcozzi Veteran Member
    3,243
    499
    May 1, 2002
    Phoenix, AZ
    Do you have inner fenders? If not, what (if anything) was added for reinforcement/replacement?
