undersized harmonic balancer hubs
Discussion in 'Engine Topic' started by 79rallysport, Jun 10, 2007.
  1. 79rallysport
    79rallysport Veteran Member
    976
    Feb 11, 2003
    Vestal, NY
    Does anybody know of a manufacturer that can make harmonic balancers with undersized crank hubs? I have an eagle crank that was machined a little too small, and the balancer I was going to use doesn't provide enough interference fit. I need one that is about .001-.002" under.
  2. tgw323
    tgw323 Veteran Member
    468
    Jun 25, 2000
    Roanoke, Ind.
    ATI s are known for being on the small side.
  3. CorkyE
    8,352
    69
    Like twg says, ATI's usually have to be honed to fit, they are intentionally under sized. Another solution is that you can buy sleeves in various thicknesses.
  4. 79rallysport
    976
    Feb 11, 2003
    Vestal, NY
    Those sleeves are only for when the timing cover seal wears a groove in the outside of the balancer hub, aren't they?
